Question about LG 42LE5500 42 in. TV
LG TV Doesn't Turn Normally
When I switched my LG TV on the screen is blank although the light on the bottom panel shows that the TV is on. It seems I've to leave the TV on (with the blank screen) for several minutes then switch it off and wait for a minute or so and switch it on again for the screen to light up and picture to show. It's like the screen needs 'warming up' time. Can you assist? Many thanks!
    Top Expert:
  • LG Master
  • 74,243 Answers
Contact the authorized service centre for LG. The fault sounds like strange.
Gopakumar Gopalan Google
Posted on Mar 28, 2014
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
SOURCE: Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Posted on Mar 01, 2009
SOURCE: LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
Posted on Jul 27, 2010
  • 3 Answers
SOURCE: LG TV - when switched on the screen is blank apart
We have same TV. Your tv is trying to go through your DVD recorder channel. Just press D/A button (top left hand corner of remote TWICE and it will go back to transmitting through TV.
Posted on Jan 08, 2011
SOURCE: My LG 37LC2D issue: when I power it up it takes a
Check the capactors on the power supply. I changed C208 because it was bugled on the top I put a 25 volt in place of the 16 volt. The green light should flash 7 times then picture is present. See http
http://lcdalternatives.auctivacommerce.com/Repair-Kit-LG-32LC2d-LCD-TV-Capacitors-P1747193.aspx
Posted on Feb 15, 2011
I have a LG 47ln5400 and when I press the power button the tv screen flashes white really quickly then nothing shows up on the screen. The red status light turns on and stays a solid color. Then when I...
First you have to check if the back light of the panel works fine . if it's okay ..
Then probably you have a problem with the T-con.
It's a small board at the back bottom side of the panel . Connected to the main board by means of LVDS cable .
Aug 05, 2017 | LG Televison & Video
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
LG15LW1R Just Gone Blank!!
Remove the battery from the back and then put it back in. This resets the TV and should get it to work again.
Feb 09, 2009 | LG 15LW1R 15 in. LCD Television
LG 42LE5500 42 in. TV Logo
155 people viewed this question
Computer Repairing
Computer Repairing
