Question about Electrical Supplies
Honda generators how do i drain the gas out of the t ank
    Sergeant:
    Champion:
  • 250 Answers
You can put a can under the carburetor bowl and remove the bowl drain bolt and loosen the gas tank cap.
Posted on Jun 27, 2014
How do i drain the gas out of the gastank on a honda 4000 generator
On my generator, I just take the fuel hose loose where it goes into the carbureator and drain it from there.
Mar 27, 2014 | Electrical Supplies
It has been sitting up for a couple of months and now I can't start it.
drain gas from carb. clean spark plug. trying to start with old/bad gas will foul out the plug.
Aug 29, 2013 | I Power In Box Honda Eu1000i Power...
How do i drain the gas tank on the ex3300
Just put the switch in on position and open the drain plug under the carburetor (check owner manual)
May 05, 2013 | Honda Ex3300 Gas Powered Generator
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
Generator does not start
The float bowl their is a drain bolt, take it out check for gas.
Aug 23, 2012 | Dewalt Generator. 6000 Watt Portable...
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
