Touchpad scrolling not working
On the edge of the rouch pad scrolling lines are there for vertical and horizontal.... thats not working
    Scholar:
  • 76 Answers
There can be two problems
1. something wrong with ur HW, which is quite negligible, as there is very less possiilty of that.
2. most possibly you dont have installed the drivers for ur touchpad. pls install that and the problem will be resolved
Posted on Jun 16, 2009
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
Touchpad must be continually tapped to make scroll bar scroll up or down
Different laptop uses different type of touch pads. If your's an old laptop, that may not have a scroll function by simply sliding your finger through the right edge(top to bottom and vise versa) to scroll to a desired level. A new laptop has all these functions. Go to the control panel click on classic view in the left pane in case of xp and vista. Then you can see the mouse icon.click on it and select the device setting tab. then click on setting and a new window will open.There click on scrolling and click on one finger scrolling you can see the scrolling properties. tick mark the vertical and horizontal scrolling boxes. click apply then ok and close all the way. Thats it All done. Hope it helps
Dec 02, 2012 | Computers & Internet
For my compaq tablet tc4400, the right side of the touch pad has a column of horizontal lines that I believe HP calls the "scoll zone." The problem is for a right hander as myself, whenever my...
Go to control panel -> Mouse -> "Device Settings" tab (has the synaptics logo to the left of it) -> Select your touchpad -> "Settings" -> expand "Scrolling" -> "One-finger Scrolling" -> uncheck "Enable Vertical Scrolling" and also uncheck "Enable horizontal scrolling"
If you don't have "Device settings" in the mouse setting window, then you need to install the drivers from http://www.synaptics.com/support/drivers
Dec 31, 2010 | Computers & Internet
How do i use my touch pad to work horizontally or vertically
To enable the touchpad scroll features, you you have to install the touchpad driver. The basic touchpad features work without the driver installed but the scrolling requires it.
http://tinyurl.com/ybvag6o
Mar 06, 2010 | Dell Inspiron™ E1505 PC Notebook
Scroll doesn't work
Update the touchpad driver. Click this and follow the wizard.
Dec 28, 2008 | Dell F3534 Touchpad
I have lost the ability to scroll using the right vertical edge of the touch pad. Otherwise the pad works fine but it is annoying not being able to scroll any more without moving the cursor to the 'scroll...
The option to enable or disable the scrolling option for the notebook touchpad is generally available by going to the Control Panel, then selecting Mouse. Within that area, go to Device Settings, select the touchpad from the list of available devices, then click Settings. There should be an option for "virtual scrolling" - click on it, and you should be given the options to turn on or off both horizontal and vertical scrolling for the touchpad control.
May 06, 2008 | Computers & Internet
Computers & Internet Logo
915 people viewed this question
David Payne
David Payne
