Question about Sharp MX-2700N Color Copier
I HAVE SHARP MX2700N COLOUR PHOTO COPIER ITS INSTLLED LANGUAGE IS DIFFERENT THAN ENGLISH I TRIED MY BEST TO CHANGE IT IN ENGLISH BUT COULD NOT DO SO PLZ WHEN I RIED TO CHANGE IT OPTION OF ENGLISH UK O
CHANGING LANGUAGE INTO ENGLISH FROM OTHER LANGUAGES
    New Friend:
    Problem Solver:
  • 6 Answers
Re-install software,after deleting your old install. carefully watch for language selection!! European English should be useable!!
Posted on Mar 27, 2014
sir fixalot
  • 146 Answers
SOURCE: sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Posted on Jan 06, 2008
tehnik_bdg
  • 91 Answers
SOURCE: MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Posted on Mar 10, 2009
007tech
  • 95 Answers
SOURCE: I have a sharp copier MX2700N with an error code
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Posted on Apr 08, 2009
  • 54 Answers
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Posted on Apr 17, 2009
  • 67 Answers
SOURCE: Code U2-05 call for service code!
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
Posted on Apr 21, 2009
Line on copies in the same place all of the time sharp mx2700n copier
Replace drum OR main charger OR clean glass OR replace blade d
Feb 11, 2013 | Sharp MX-2700N Color Copier
I want to change opperating language on my machine
If we are talking about Windows XP, there is a small icon in the right bottom corner stating two letters. Click on it and change to English. Or look under REGIONAL AND LANGUAGE OPTIONS in the control panel. ADVANCED tab.
Sep 14, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do I change the the language setting from
To Change the language to English-Press the additional funktion key (The sircle with a star button)
Scroll with the arrows untill no 12 press OK.Scroll untill English is displayed.Press OK
Let me know
Dec 04, 2009 | Canon iR 2016i Black and White Copier
Press # key
press * key
press C key
press * key
enter 16
press start key
Good luck
Apr 20, 2009 | Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
Apr 17, 2009 | Sharp MX-2700N Color Copier
Feb 19, 2009 | Sharp MX-2700N Color Copier
Language problem
for all android phones version 1,5 and later you can go to a free android market and download the programs 'MoreLocale' and 'Set Locale and Language' . you can change the language into any language u want.
Jan 17, 2009 | HTC Touch Dual Slider Smartphone
Would like to change Language settings for Epson Stylus Photo R290 Series Printer... Currently when printing a Test and when I go to the Print Preference, its showing as a foreign language... How can...
1. First of all, you must completely uninstall your current driver (with foreign language).
2. Download Epson R290 English Language Driver from here :
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&mfalse&catid=1&pid=1259
3. Unplug your printer USB Cable from your PC
4. Run : Setup.exe
5. Follow the instruction, and thats it. You've English Language now :)
I have tried this and it worked :)
Aug 28, 2008 | Office Equipment & Supplies
Xerox Docucolor 12 color copier language problem
Hi, there is no way to change language on Touch screen without calling Service. Best regards.
Dec 27, 2007 | Xerox DocuColor 12 Color Copier
Sharp MX-2700N Color Copier Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
