Algotex firmware must be configured
Algotex plotter
you need configuration file save ...here my e-mail address if you still need solution dan.mataragiu@gmail.com
Mar 28, 2014 | Boating
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
Download file now send rfu upgrade on usb dev port
Determine the current firmware version 1. Press Menu . 2. Press the down arrow to highlight INFORMATION, and then press OK. 3. Press the down arrow to highlight PRINT CONFIGURATION, and then press OK to print. The firmware datecode is listed on the Configuration page in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.***.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20061125 represents November 25, 2006. Download new firmware from the HP Web site To find the most recent firmware upgrade for the product, go to www.hp.com/go/ ljp4010series_software or www.hp.com/go/ljp4510series_software. This page provides instructions for downloading the new firmware version.
Aug 05, 2011 | HP LaserJet P4015N Printer
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
Stuck in safe mode
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration.
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration.
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration.
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 27, 2010 | Logitech Harmony 520 LCD Remote Control
Some of the configuration pages are blank
you may need to reflash its firmware. probably faulty firmware that caused some of its admin pages to be blank
Nov 07, 2009 | IOGear (GWA502) Router (DHGWA502)
Bittorrent configuration problem
The new firmware already has bit-torrent capabilities built into it. Please do the following:
1. Download the latest firmware from D-Link website
2. Save your configuration in case there are any problems
3. Upgrade firmware from the DNS-323 menu
May 05, 2009 | D-Link Dns 323 2-Bay Network Storage...
Graphics print with pink background
That is a firmware issue. You can go to Xerox.com and follow these procedures.
Print a Configuration Report and review the Engine Firmware Version section to determine the firmware version. See the Related Items below for additional information.
Firmware version 05.08.00 or higher can be installed to resolve the image quality problem. If necessary, upgrade the firmware version. See the Related Items below.
If the printer's firmware version is currently at 05.08.00, replace the Print Cartridge. See the Related Items below.
elem_1_spacer.gif Related Items:> Go ToMicrosoft Windows OS Firmware Update Version 05.08.00
> Go ToApple Macintosh OS Firmware Update Version 05.08.00
> See AlsoHow To Print the Configuration Report
> See AlsoHow To Replace the Print Cartridge
Feb 10, 2009 | Xerox Phaser 6180N Laser Printer
Configuration Error while starting up...
you need to update either the firmware or your settings . firmware can be updated using the sony eric pcsuite and conection settings / configuration can be got from your service provider
Oct 30, 2007 | Sony Ericsson K750i Cellular Phone
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
