Question about Jenn-Air JJW8230D Electric Double Oven
Cooling fan will not stop even when oven isn't turned on.
Cooling fan will not stop even when oven is turned off.
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
The fan doesn't turn off even the oven is not in use,the cooker is almost brand new
draft fans are not usually controlled by any front panel controls , no they work strictly by temperature , they keep going till oven cools off then shut down , now if it never stops even if oven is ice cold , then the control that feeds fan is defective and needs service
Sep 28, 2015 | Ovens
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Jun 15, 2009 | GE Profile JT912 Electric Single Oven
Self cleaning oven the fan will not go off after
Self cleaning ovens usually use very hot temperatures. Therefore if your fan is designed to help your oven cool, it will run until your oven is cool. Leave it running until your oven is cool and it should stop. It it does not let me know.
Jun 09, 2009 | Ovens
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Oven Fan won't turn off. Has to be turned off at main power source in order to stop it.
my fan took 30 minutes after cooking to turn off. i think it may have to do with the fact that it is trying to cool the oven?
just wait for 30minutes - 1hr to see if it stops and open the oven door all the way to speed up the cooling
Jan 08, 2008 | Fisher and Paykel OS302SS, Stainless Steel...
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
