No sound out of suzuki sp 37 what do i do to fix this
Sound comes out of speakers like the crackin when its powering on but none of the buttons or keys will give me sound and all the button lites are working how can i fix this
  • 98 Answers
That might be loose contact with ur speakers.. check it...
Posted on Mar 27, 2014
SOURCE: HP Laptop sound and power button trouble
You don´t have to replace it. Just cut about 1,5 - 2 cm off the end (that´s where mine was broken) and scrape the tracks free with a knife. Then but a small batch of tape behind the end so it will be held in the socket. That´s it, a 10 min fix.
Posted on May 11, 2008
  • 7 Answers
SOURCE: Power button and speakers quit working
This is a common problem, the cable that connects the button board to the system board goes bad. Usually but not always the power button stops working as well and the speakers. Replacement cables can be purchased on eBay or from: www.2fix.net. Its fairly easy to replace the cables.
The screws for the panel with the power and Multimedia buttons are located under the battery. Remove the battery, then the 3 silver screws. You also need to remove the keyboard to get to the other end of the cable. There are 3 black screws to remove; 2 in the battery bay, and 1 in the memory bay. The keyboard screws are identified ay a small keyboard icon.
Posted on Aug 18, 2009
  • 95 Answers
SOURCE: none of the buttons on my keyboard work
Sounds like the keyboard got wet. If not and you feel there is no damage from anything else it is possible that you might need to reload the software; if you have it. I don't know the age or model of your laptop but you should be able to plug in a PS2 or USB keyboard and see if that works. If so then you definitely have a keyboard problem.
Posted on Sep 12, 2009
firesnake09
  • 2923 Answers
SOURCE: no sound when computer is being shut down or
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Posted on Sep 12, 2010
  • 452 Answers
SOURCE: push power button,keyboard lites then caps key
common issue for HP. check out http://www.bootmylaptop.com for a diy guide.
Posted on Dec 28, 2010
Philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Sep 07, 2007 | Philips HTS3440/37 System
Model.no sp-pwc5 the power wont come on at all how cam I fix it
sounds like the power supply you will need to change it or have it changed
Mar 18, 2010 | JVC SP-PW100 Subwoofer
Our 37" series 4 (450) LCD TV sound "garbles"
Hi my name is Roety,
I can help you with your issue ,
Make sure you have the latest firmware upgrade from Samsungs website!
Also weak signal can cause this if using air signal raise or connect a better antenna
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 29, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
Hi Folks, I've got a sharp LC-26SA1E.The sound problem I have is that it only has 3 sound levels.None, Loud(30) and house shaking loud (60).There is an error code that has come up in the top left hand...
While tv is off press and hold buttons on tv VOL(-), A/V and switch it on, release buttons after 5sec.
Suppose to get back to normal state then.
I checked on my old sharp lcd lc-32ra1e and worked.
Oct 29, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I have the philips hts3440/37 none of the speakers work.
Doubtful that it is as serious as a fuse, unless it was working before and now it's not.
Are you getting no sound when watching DVD's? Try adjusting the volume on the home theater system - press the SURR button until it says "Dolby" or something like that.
Make sure it is connected like this:
Feb 21, 2009 | Philips HTS3440/37 System
Soundcard problem acer aspire 5735
Try reinstalling sound driver. if still the same issue try external speaker to check if they have same issue. if external speakers work fine that mean its not driver issue and problem with your notebook speakers replace them.
Good Luck
Feb 04, 2009 | Acer Aspire 5735 Notebook
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
May 12, 2008 | Janome 8080 Computerized Sewing Machine
I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
May 07, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
