Question about OnlinePartsBin 1998-08 Volkswagen Polo 7d Indigoblau Pearl Professional Touch Up
1.9tdi polo cruise control - OnlinePartsBin 1998-08 Volkswagen Polo 7d Indigoblau Pearl Professional Touch Up
My vw polo 1.4litre 2001 is not picking speed as l drive through a rise
assume you are using cruise control speed should not increase just rpm,s might increase when the transmission down shifts to mantain constant speed .
Feb 27, 2015 | Volkswagen Polo Cars & Trucks
Tip
TROUBLESHOOTING WHY YOUR CRUISE CONTROL DOESN'T WORK
There are many things that can cause your cruise control to act up or not work at all. This article will lead you in the correct direction on finding a solution to your problem. This article is for any type of vehicle.<br /> <br /> <b>If your cruise control won't hold proper speed, </b>you need to look at the following parts. <br /> <ol> <li>Faulty Cruise Control</li> <li>Faulty Speed Sensor</li> <li>Faulty Vacuum or Vent Valve</li> <li>Faulty Stepper Motor</li> <li>Faulty Transducer</li> <li>Incorrect Cable Adjustment</li> <li>A Binding Throttle Linkage</li> <li>Leaking Vacuum Tank</li> <li>Leaking Vacuum servo diagram</li></ol> <b>If your cruise control surges, </b>check the following parts.<br /> <ol> <li>Faulty Cruise Control Module</li> <li>Faulty Speed Sensor</li> <li>Binding Throttle Linkage</li> <li>Kinked Speedometer Cable</li></ol> <b>If your cruise control cuts out on you, </b>check the following parts.<br /> <ol> <li>Faulty Transducer</li> <li>Faulty Cruise Control Module</li> <li>Short or Open Circuit in Cruise Control</li> <li>Brake or Clutch Switch Adjusted too tight</li></ol> <b>If your cruise control doesn't work at all, </b>check these parts.<br /> <ol> <li>Faulty Cruise Control Module</li> <li>Short or Open Circuit in Cruise Control</li> <li>Faulty Clutch or Brake Switch</li> <li>Leaking Vacuum Circuit</li> <li>Faulty Stepper Motor</li> <li>Faulty Speed Sensor</li> <li>Faulty Transducer</li> <li>Faulty Cruise Control Switch</li> <li>A Blown Fuse</li></ol>
on Jul 20, 2011 | Ford F-150 Cars & Trucks
Fuel pump polo
Hi Emanuel
your polo seems to have a problem with the diesel pressure sensor,
I am sure when it loose it's power you see the check engine light on.
it should be connected to a diagnostic machine, you'll see that I am right.
good luck
Jan 18, 2014 | Cars & Trucks
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
On these case,to troubleshoot these problem,there are solved help links.Click the link directly and refer the details to solve these problem yourself,with help of diagrams:------
----------- Horn and Cruise control quit working?
Horn and Cruise control quit working on 2003 Jaguar S-Type? http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These will help.
Thanks.
Nov 22, 2012 | 2003 Ford Expedition
Cruise control don't work
To troubleshoot your problem,there are few help links,provided below.Click the link directly and follow the procedure to confirm the fault.So as per that you can continue further in repairing this issue of cruise control not working.
The direct help links are as follows :-----cruise control not working?
-----------Horn and Cruise control quit working?
Horn and cruise control not working on car?
Horn and Cruise control quit working suddenly?
Cruise control stop working ? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/2005-ford-ranger-cruise-control-not.html
My Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
This troubleshooting help links will help you to confirm the problem.
Thanks.
Feb 13, 2012 | Chevrolet 3500 Cars & Trucks
Whats wrong with my jaguar x-type 2003 after i start the car then drive off the amber light says cruise control not working,, then it also stall's or hessitates when trying to excellerate or pass another...
I have exactly the same problem on mine-you explained perfectly,i was told i need to change the cruise control computer.I recently had the thermostat changed and the mechanic wiped the engine sign off that was triggered by the cruise control not available sign coming on-when he did this it took about a month for the problem to recur so i think the probelm is definately electrical not mechanical or it would have happened straight after he wiped the engine sensor light.could be air mass sensor could be cruise control computer-when i get some money i'll get it done
Dec 31, 2010 | Jaguar X-Type Cars & Trucks
I have a Polo 1.9TDI with gearbox noise. The gears change smooth and still have its normal power, also no power loss Can you advise
Wut kind of NOiSE? Do u hear the noise when u change gears? Hear it when ur in normal cruising or in high speed? Tell us more pls.
Nov 15, 2010 | 2005 Volkswagen Golf
WV polo 1,6 1996 low idle RPM
try cleaning the throttle body with carb cleaner and then put it back through basic settings by carrying out a road test under the following conditions hard acceleration, cruising and over run, that may cure it
Jan 11, 2009 | 1997 Volkswagen Jetta
OnlinePartsBin 1998-08 Volkswagen Polo 7d Indigoblau Pearl Professional Touch Up Logo
Top OnlinePartsBin Water Sport Experts
Bill Boyd
Tom Chichester
Are you an OnlinePartsBin Water Sport Expert? Answer questions, earn points and help others
