Question about Casio Office Equipment & Supplies
Can you do the highest common factor on an fx-83GT PLUS casio calculator
I don't know how to do the HCF on a casio calculator fx-83GT PLUS and I would like to know the simplest way to do so
  • Casio Master
  • 8,064 Answers
The calculator has no application that will find the highest common divisor (or HCF) but that should not be difficult to do by hand.
Decompose the first number in prime factors. If a prime factor is repeated use the exponent notation: That helps
Decompose the second number in prime factors too, using the exponent notation.
Now look at the two decompositions. If a prime factor is present in both decomposition it must be in the HCD /HCF, with the smallest of the two exponents. Do that for all prime factors
Example;
(2^5)*3*(5^4)(7^3)*11
(2^3)*(5^6)*(11^2)*7
The prime factors that are present in both decompositions are
2, 5, 7, and 11
From the two decompositions select the smallest power of each
2^3, 5^4, 7, 11
The highest common divisor/Highest common factor is
(2^3)*(5^4)*7*11
Posted on Mar 27, 2014
SOURCE: Factoring polynomials "Algebra"
Mode>choose "5"
choose equation format "4"
input the coefficient for a which is "1" and hit "="
input the coefficient for b which is "4" and hit "="
input the coefficient for c which is "3" and hit "="
input the coefficient for d which is "12" and hit "="
Hit "=" for X1
Hit "=" again for X2
Hit "=" again for X3
Posted on Oct 20, 2008
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
  • 102366 Answers
SOURCE: is there any way to stop the casio fx-83GT plus
Yes. Press SHIFT MODE 2 to select the LineIO mode.
Posted on Nov 05, 2010
  • 457 Answers
SOURCE: The Tan, Sin and Cos
Press [SHIFT] [MODE] [3] to switch to degrees.
Posted on Jan 10, 2011
  • 8064 Answers
SOURCE: I have a casio fx-83gt
The computational mode of your calculator is set to VERIFY. Change it to the general COMPUTATIONAL mode. Press MODE 1 (COMP).
Posted on Jun 06, 2011
My casio fx-83GT Plus calculator wont do HCF for me
There is nothing you can do to make the calculator find the HCF for you. No point complaining about that. But if you are interested in doing it by hand (using the calculator to do the divisions for you) here how it is done.
  1. Decompose the first number in prime factors. If a prime factor is repeated use the exponent notation: That helps.
  2. Decompose the second number in prime factors too, using the exponent notation.
  3. Now look at the two decompositions. If a prime factor is present in both decompositions it must be in the HCD /HCF, with the smallest of its two exponents.
  4. Do that for all prime factors
Example: Here are the decompositions of two numbers
(2^5)*3*(5^4)(7^3)*11 and (2^3)*(5^6)*(11^2)*7
2, 5, 7, and 11
From the two decompositions select the smallest power of each common prime factor. They are represented in bold fonts.
2^3, 5^4, 7, 11
(2^3)*(5^4)*7*11
Mar 27, 2014 | Casio Office Equipment & Supplies
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Casio fx-83GT-plus how to convert binary to hexadecimal
Sorry to be the carrier of bad news but the Casio FX-83 GT Plus does not have a baseN calculation mode. You cannot do any arithmetic in binary, octal or hexadecimal numeration.
Oct 06, 2013 | Casio Office Equipment & Supplies
Casio fx-83GT plus how to convert binary to hex
I have just changed from using a Casio fx-83MS to a fx-83GT Plus. Is there a way of displaying a comma between every third whole number?
I do not think that Casio scientific calculators have the possibility to separate thousands, millions etc. The Sharp have that feature.
Sep 15, 2013 | Casio Office Equipment & Supplies
Mod operation in fx-83gt plus
Like many other Casio calculators, the fx-83GT Plus doesn't provide the modulus function. You have to do it the hard way.
To calculate 19 MOD 10 (which is 9, not 10 as you state in your question), first divide 19 by 10 and note the integer portion of the result (in this case, 1). Then subtract from 19 the product of 10 and the result of the first step. The result of the subtraction is the modulus. 19 - (1*10) = 9.
May 10, 2013 | Office Equipment & Supplies
Casio fx-83GT PLUS gives wrong values for logs
Are you using the right type of logarithms? The calculator provides for two types: common (base 10) and natural (base e).
Could you post an example or two, with the answers you get and the expected answers?
Apr 15, 2013 | Casio FX83ES Scientific Calculator
Casio fx-115es plus how to find the LCM
I have a fx-570ES plus instead but one easy way I found to calculate the LCM us by adding 2 fractions in the following format: 1/a + 1/b, where a and b are the numbers you are calculating the LCM for. In my calculator the result is displayed as a fraction, with the denominator being the LCM. From there I can also figure out the HCF with the following formula: HCF=(a * b) / LCM. In some calculators the fraction might get displayed in decimal format but most of the newer ones can switch between fraction and decimal format. I hope this helps.
Jun 11, 2012 | Casio Office Equipment & Supplies
Can't change from standard form on my casio fx-83gt plus
There is only one key to toggle between display formats: the S<>D key. Pressing the key repeatedly will cycle through all available display formats.
May 23, 2012 | Casio FX300WPlus Scientific Calculator
306 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
