Question about Samson Audio Players & Recorders
Popping sound irradically
Unit pops often pierodically without any change of handling, location or disturbance of any kind.
    New Friend:
  • 98 Answers
It might be loose contact.. try to resolder it...
Posted on Mar 27, 2014
The freezer side of this unit quit freezing. Everything is thouging out. Fridge side isn't as cold as it used to be. Both controls have been set on factory recomemded settings since install. I keep...
A popping noise? Could it be the clicking of a relay? There is a relay that activates the compressor that could cause a clicking sound if it doesn't hold. A popping sound could be a bad capacitor but normally isn't a continuous popping sound, unually only one pop.
If the unit is only 4 monthes old it should still be under warranty and you should call it in for repair.
Jun 16, 2011 | Refrigerators
I have a mxl 990 microphone and its hooked up to a Pro tools LE 8 Mbox Mini . when im recording on protools or any other software with this mic, i hear a static/popping sound and it records the popping...
Try increasing the latency. Depending on your computer, it may not be able to handle low latency levels. Latency is a measure of the delay between the time you make a sound and the time the computer records that sound. With the Mbox mini, the unit for latency is the number of samples the driver collects before sending them to an application as input. Lower latency can make recording easier and more accurate, but not all computer systems can operate at the lowest latencies without introducing noise. Open the Mbox mini dialog and select the latency tab. experiment with higher latency levels and see if it goes away. somervta_0.jpgThis is what the dialogue might look like. another solution would be to try a different DAW. I had the same problem with my Fast Track Pro in ProToolsand it worked fin on Reaper, Garageband and Logic.
Jan 17, 2011 | M-Audio MXL 990/991 Recording Mic Duo and...
My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
Flash made loud pop sound.... like balloon popping. doesn't flash anymore. why would this happen?
It sounds like the flash tube itself blew out. This could be due to a number of things, from the age of the unit, to the electronics, to a defect or mistake in production.
Another reason could be using a flash that is not dedicated to your type of camera. Flash trigger voltages differ between make and model creating many incompatibilities.
Without more info, I cannot suggest what flash would be best for you. Sorry.
You can goto yahoo groups and find a group for your kind of camera. Ask other members what they suggest for your camera, budget and what you do with your camera.
Dec 25, 2009 | Cameras
M602 Speaker Problem,.. Popping Sound
This worked for me on my M604: Try inserting/removing a headphone plug into the jack several times to see if that clears the problem.
The "popping" sound is very similar to the sound that the unit makes when inserting headphones into the 'headphone' jack on the back of the unit.
The jack has a contact switch that triggers a relay inside the unit. If that contact switch is 'on the verge' of making contact, slight temperature changes may cause deform closer to it's contact target. The subsequent capacitance build-up and discharge across the gap could explain the cycle of popping noises after the unit warms up.
Jun 25, 2009 | Altec Lansing M604 Computer Speakers
15 inch velodyne subwoofer making a loud popping sound
If you have changed the signal source, then these may not be the problem at all, it may be that you have the sub output set to low on your processor.
This may be one of these problems.
It could be the "auto on" circuit.
If you change the switch on the back of the unit to always on does it still do this? if not then it is the auto on circuit that is the problem.
The driver mounted servo unit is starting to fail.
A cap in the amplifier input section may be going bad.
You nwill need to contact Velodyne for repair of the unit.
Feb 20, 2009 | Velodyne HGS-15 Subwoofer
Irradic reading at oil pressure guage
The sending unit would be the first thing to change, at least it would eliminate that.
Jan 25, 2009 | 2000 Jeep Grand Cherokee
Popping sound from sub woofer
disconnect the woofer and connect a different speaker see if other speaker makes the same pop if it don't then the woofer cone is defected if you have high watts and using stereo on high volume you can damage speakers.
Feb 08, 2018 | Yamaha HTR-5550 Receiver
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
62 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
