Question about Uniden GPS
Battery Removal for Uniden iGO500
Uniden starts booting but freezes at the Uniden screen.
My alcatel onetouch 5020d freezes on boot
Sounds like it has been damaged. The only other thing I can think of is remove the battery for a few hours and try again.
Nov 28, 2014 | Alcatel Cell Phones
Hp freeze in Windows Start
Try these steps:
1) Turn off your laptop
2) Pull the Battery out
3) Turn the laptop on
4) If it does the same thing, put the Battery back in and reboot it
Doing this may reset the Bios and get your PC booting back into Windows. Please let me know if this helps!
--Andrew
Jun 15, 2013 | Computers & Internet
I have just purchased a UNIDEN GPS iGO500. I've registered the device and tried to download Naviextras Toolbox but when trying to extract my laptop is saying that there is a virus in the program. I...
I got mine connected finally, the problem is you have to put the GPS in USB device mode not just charge mode, however the screen with this option on it fails to appear when you turn it on. I got a breif flash of it as I was turning it on and off and the USB mode button is to the right of center. Have to device plugged into the computer and turn it on when the loading screen appears keep pressing your finger to the right hand side and you will trigger the USB mode.
Sep 14, 2011 | Uniden GPS
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    Flip Video Mino keeps freezing up, can't shut down or upload
    At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
    Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
    Uniden trax 430 frozen
    I have had a similiar problem with my Trax 430. The screen freezes at the system shut down stage. I have to plug it into the computer via the USB cable. It then recognizes the computer and attempts to do an USB update. Then just unplug it. It should work but not a practical solution when you are driving about.
    Jul 10, 2009 | Uniden TRAX-430 GPS Receiver
    My RCA TH1611 mp3 player freezes upon booting.
    Sometimes the firmware or player files are garbaged and the player looks like it starts halfway then freezes. If this is your problem and you're sure the battery's fine (and in the right way) then you can try to reload the flash on the player and as a last resort reformat the file area as well.
    Go the RCA support website and download the latest flash for the th1611 and run the program. You may be lucky off the bat, but if the first attempt fails review the troubleshooting procedures that will tell you to hold the play button while plugging the device into the usb port. If, after the program flash, the device still fails to start, you'll have to erase the file area to un freeze the device.
    I had a weak battery that that I pulled out while the device was starting and it seemed to corrupt the player. Thisprocedure worked for me.
    FYI, the flash program works on XP 32bit, but I don't know if it will work with Vista
    Jul 07, 2009 | RCA TH1611 MP3 Player
    Freezing up
    I think you need to do a power cycle. remove the battery and use tha AC adapter alone. If it boots, then thats good. U can try also booting on safe mode by pressing F8. Then re start the notebook in normal mode. If it wont works then i think u need to reinstall windows as a last resort. U need to use TOSHIBA RECOVERY DISK this time.
    Sep 05, 2008 | Toshiba Satellite A105 Notebook
    My nokia 6111 freezes while i was slide up
    try to change your battery but if still autoshut off you need to reformat your phone
    Aug 02, 2008 | Nokia 6111 Cellular Phone
    Windows xp freezes on boot up after it lists the intel celeron 2400 MHz Processor
    if your not using laptop , if you are using pc then just do as i say ....
    there is some problem in bios...so,
    open your cpu and remove the lithium cell battery which will be in coin size and then boot after removing battery once ....
    once again after 5 mins insert the lithium cell battery and reboot your pc now you can enter in to your bios set up and just have a have whether all the devices you have connected are detected or not....
    (if it is a laptop then also you can do the following by entering into bios setup)
    then make sure about those boot priority devices , in this you have given the harddisk for boot up .....
    this solves your problem ....
    Feb 22, 2008 | Microsoft Windows XP Professional With...
    GPS Logo
    71 people viewed this question
    Top Uniden GPS Experts
    Martin Murray
    Oloyede Monsuru
    ZenFire
    Are you an Uniden GPS Expert? Answer questions, earn points and help others
