Question about ASUS P5PE-VM Motherboard
My computer problem is i press power button and then show motherboard logo and then go to bios setting. not direct to go winxp logo why?
  • 700 Answers
Are you using a desktop? Then check first your bios settings, or you need to change your cmos battery. Are you getting to set the date whenever you start it up?
Posted on Jun 15, 2009
  • 431 Answers
Hi I am Vortash I have had a problem like this once before , not sure if it is the same problem but you can try this .
check that the keyboard is on PSU and not USB depending on which type you are using .. check ( and as mine was ) the delete key is not pressed down or stuck telling the unit to go to Bios .. check that you don't have a faulty HD make sure it is spinning up you should be able to hear it read and spin .. if you have more than one ram slide inserted take them out leaving only one try a start up with each one individually .. if all this fails I would suggest it is a CPU fault not holding data .. hope this helps regards Vortash
  • clive pearson
    clive pearson Jun 15, 2009
Ecs 945gct m3 v h motherboard ver 3.1
Your motherboard keyboard controller is not initializing completely. The three LEDs shows the keyboard is powered and initializes, but the motherboard keyboard controller looks to be bad. I assume the keyboards work on other computers. Make sure there are no jumpers on the motherboard for the keyboard. You said the video screen is stuck on CMOS BIOS logo and is trying to continue with a missing keyboard or keyboard error. So since it got to the BIOS screen, pretty much everything else came up.
Jan 13, 2014 | Computers & Internet
Acceso a bios
Look at the bottom of the monitor screen, when the manufacturer logo comes up
Gigabyte?
Look for -> enter BIOS Setup <- and the key to press
If Windows loads, let it load. Then turn the computer off normally.
(WinXP: Start > Turn Off Computer > Turn Off )
If Windows does NOT load, press the CTRL key, ALT key, and DELete key AT THE SAME TIME. (Not shouting)
Or press the Power On button, and hold in for a count of 10 seconds.
Now...........
AS SOON AS you press the Power On button, start tapping on that enter BIOS Setup - key.
Tap in 2 second intervals.
If you hear beeps ignore them.
They are Stuck Key Error Code beeps, and it is you that is doing it
This method will get you into BIOS Setup.
Regards,
joecoolvette
Apr 13, 2013 | Gigabyte Computers & Internet
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
Regards,
joecoolsvette
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Computers & Internet
I cannot access my Bios setup when pressing the Delete on start up
Try pressing the esc key if that doesn't work use the f12 key
Nov 11, 2012 | Intel Motherboard
P5e3 deluxe motherboard. Computer starts ok but with nothing on the screen until the welcome logo. This means cannot get into bios or safe mode. Computer runs well otherwise
Your bios may be set for quick boot, and does not show the bios information. You can still access the bios by hitting F2(or possibly DEL) right after powering up. You can then change settings inside bios
Jun 22, 2011 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
How do I get rid of the soyo dragon off my computer. It is the first thing I see after I turn on my computer
You can turn this off in your Bios settings.
To do this, press delete when computer starts booting up and this will open the bios screens.
Go to Advanced Bios Features and look for 'Full Screen Logo Show', set this to disabled.
Some of the soyo boards will vary in how you do this so just look at what yours has in the Advanced Bios page, some you will change the Logo size to make it go away and another you switch between Logo-0 and Logo-1.
Lastly, if you are running the p4i865pe plus dragon 2 v1.0 board and/or bio version 865dp1a2 there seems to be no way to get rid of it (updating that bio version to the newest one may change that though)
Hope this helps you resolve the issue!
Feb 24, 2011 | Soyo Computers & Internet
Hi all I have 945 motherboard, 1GB ram, intel 2.5GH proccessor whenever I tried to install Windows vista or Windows7 the setup start but It stops at windows7 logo(where four logo color gets together and...
If you are having problems installing windows 7,you might wnat to go into your bios main screen and see if your hard drive(sata mode) is set to IDE.If so,set it to AHCI mode,as any operating systems above windows xp will not install on IDE mode.Hope this solves your problem :)
Feb 22, 2011 | Computers & Internet
How to setting the bios?
To access the bios on *********** board reboot your computer and Immediatly begin pressing the "Delete" button. Continue pressing the button every second until the bios shows on the screen.
Here you can change many settings that will tune your computer.
Thanks.
Nov 01, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Why Windows don't want to boot with this mainboard - showing BIOS ist not ACPI compailant. BIOS Version 1.89.
probably BIOS is partly corrupt. you can try the followings:-
insert winXP bootable installation cd. and start pressing F5 button to invoke the types of computer. then select Standard PC by pressing enter. the rest in windows setup.
Jan 25, 2010 | Arima HDAMA (ZCEF917NNNNNNN) Motherboard
Help
you need to configure your bios setting by doing so, your 1st boot device must be cd rom. how? upon power-on you need to press the delete button to appear the bios then configure setting as stated above then save and exit. note, cd winxp must be inside cd rom to start your format operation.
Nov 25, 2007 | ASUS A8N-SLI Motherboard
ASUS P5PE-VM Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
