Question about Konica Minolta bizhub Office Equipment & Supplies
What does trouble code C-1292 mean on a konica minota C7000
Im getting a service codec-1292 im getting a service code c-1292 on my screen
    New Friend:
    Problem Solver:
  • 6 Answers
Some research online suggests 'stack oveflow, and possible need of drum replacement. try site 'error 1292 in mysql' good luck!!
Posted on Mar 27, 2014
SOURCE: copier konica 2223
The problem is your toner density sensor, either your sensor is bad, someone reset p.m. count without running density reset mode. turn machine off hold down 4 then 7 while turning machine on, select 5 then 1 press start print.
Posted on Jan 06, 2008
checkitright
  • 1362 Answers
SOURCE: Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Posted on Aug 25, 2008
  • 32 Answers
SOURCE: Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Posted on Jul 03, 2009
  • 7 Answers
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Posted on Mar 04, 2010
mangjuno
  • 11 Answers
SOURCE: konica c7000
Try cleaning the corona wire housing by disassembling it and washing it with dish washing liquid, or replace it with new. or maybe you got the wrong corona wire. or maybe try to install it the right tightness.
Posted on Apr 17, 2013
How can I enter service mode on a Konica C7000? It is in fault mode with a code of C3501
This reset procedures reset the copier fuser the hot part if the code comes back aftyer procedure DO NOT DO AGAIN IT CAN CATCH ON FIRE RUINING A PERFECTLY GOOD DAY!!!!!!!!!!! Get a tech out to look at it
1. Be sure that the ordinary operation screen *1 is displayed.
Press [Utility/Counter] button.
2. "Utility screen"
On the Operation panel, press the following buttons.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
When the CE password has been set, entering the password is required to enter the service mode.
3. "Service Mode Menu screen"
The service mode appears.
*1 Default is [MACHINE] screen.
go to
03 System Setting
• 01 Software DIPSW Setting
set the DIPSW 3-1 to 0.
why you do it once then get a tech out to look at it. DIPSW3-1 is set to 0 before defective parts are fixed, it may cause fire
Jan 04, 2016 | Konica Minolta bizhub Office Equipment &...
My konica minota c451 is showing erro code c2551 and the print out is not sharp?
Remove the cyan (Blue) image unit. shake it along its axis. Are using 3rd party toner and image units replace with OEM. Open close front door to reset. Replace the image unit
Sep 09, 2015 | Konica Office Equipment & Supplies
How to replace the drum in konica minota bizhub 184/164
It looks like a service part rather than something you can change yourself as it may be buried in the guts of the machine. Not saying that it isn't possible, but does the machine hinge up at all?
Sep 30, 2014 | Konica Minolta - bizhub 20 Laser...
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
Konica C7000 stopped printing C-0213 error code came up
The paper exit pressure
home sensor (PS10) does
not turn ON within a
specified period of time
after it turns OFF.
one this mite be bad:
AC drive board (ACDB)
• Printer control board
(PRCB)
• Paper exit motor (M54)
• Paper exit pressure
sensor (PS10)
recommended you have a tech look at it believe the tech bulletins on this problem
Jan 07, 2014 | Konica Minolta C6500 C5500 C6501 C6000...
Does anyone know how to reset counters on bizhub c7000?
Enter in the service mode and select counter mode and reset a counter to selected parts.
Apr 05, 2013 | Konica Minolta Konica Kit For Bizhub Press...
Konica c7000
Dec 17, 2012 | Konica Minolta Konica Kit For Bizhub Press...
The focus is blurred and when you use the zoom it still will not focus. My camera is a Konica Minota Dimage Z3 4.0 mega pixels.
lens including the focousing unit must be serviced,while u focous press click button half way till u get green led glow,then click.
Apr 09, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
71 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
