Question about Facebook Apps
Change settings how do I change my laptop settings from mobile to desktop
Change my settings
You will see at the bottom of the website desktop view or mobile. Sometime the setting if based on your account what view you setup. But basically go to the bottom of the website and will say desktop. Hope this help.
Mar 27, 2014 | Facebook Computers & Internet
Tip
Mobile Security: How to secure your mobile data
Mobile Security TIP description Mobile Security TIP
Hacker Protection 1. Change Mobile device passwords at least once a month
Anti-Virus, Malware, Spyware, trojans 2. Add protection to your mobile devices like you used to do with your desktop and laptop
WEP Wired Equivalency Privacy - do not use
WPA2 Wi-FI Protected Access - USE (on wireless router and on all mobile devices)
802-11i more secure protocol for wireless -EAP (extensible authentication protocol) mode of WPA and WPA2
Hidden SSID just because you have designated your SSID to be hidden that does not mean it is secure. there are apps to find and figure out your SSID (Service Set Identifier)
WLAN Wireless Local Area Network
Software Variations MOBILE SECURITY
on Jun 24, 2014 | Computers & Internet
HP Pavillion with Vista won't display on external monitor.
Re-boot the laptop. Verify that the "POST" operation comes on during the restart - if not then you have a graphics issue in the laptop.
Feb 13, 2013 | Computers & Internet
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
What is BIOS?
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer.. this will reset your cmos
b>
Jan 03, 2013 | E-Machines eMachines Desktop PC
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Feb 02, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba L10 display will not work.have pressedfn+f1 and fn+f5 but to no avail.
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?). 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 22, 2010 | Toshiba Satellite L10 Notebook
Unable to connect my laptop to the TV
did you restart after you made the changes,usually sometimes you may have to
Jul 19, 2009 | Dell INSPIRON 600M HARD DRIVE CADDY 6X609...
I can't get any wireless internet on my laptop
here is a little bit of information for free ... if your pc or laptop is built by a well known brand or has vista installed you might want to change the power saver options BECAUSE A LOT OF PC MANUFACTURERS CHANGE THE POWERSAVING SETTINGS with their own settings and i found on several models when in battery mode it was impossible to connect to wireless network ..however just open power options and go to advanced settings and set the wireless to max performance on bat and on mains power,,,,,,,, other than that open mobile pc setting in control panel and make sure wireless switch is on
Jun 30, 2008 | Sharp Computers & Internet
Wireless fails to operate sometimes on Amilo Pi1505 laptop. Have tried switching wireless on and off without success. After a couple of days it will suddenly start operating again without imput from me.
It may be a compatibility issue betwen the mobile device and the router. Find the router model/name as well as the mobile card or built in mobile device manufacturer/model name so that I may research this further. Some settings in My Network Places will allow you to change how your mobile device will act. For example, you can change the settings so that it ONLY looks for the specific network in your home, rathe than searching for the strongest signal which may cause you to lose connection while it looks around. Another factor to consider is location location location. Where is your router in relation to the laptop at the times that you are losing signal? Consider how many walls it has to go through, or floors if its upstairs and you are downstairs.. Try changing some of those settings and find out those model names, then get back to me to let me know how things go and we will go from there. Good Luck!
Apr 17, 2008 | Computers & Internet
Facebook Apps Logo
32 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
