Question about Gear Head WIRELESS keyboard/Mouse
Power pc eject button gearhead keyboard
Cd eject button
Cd will not eject from Mac laptop
To eject a CD from a Macintosh, start from power-off. Press the power button, and immediately hold down the trackpad button. Continue to hold the button until you hear the optical drive eject, or try to eject. If the CD does not eject successfully, then it is physically stuck, which is a different issue and requires professional service, which may involve replacement of the optical drive.
Jul 12, 2010 | Apple MacBook Mac Notebook
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
Cd player will not eject holds 6 cd 2001 ls licoln says cd error
This happens to me as well, usually if you press and hold the eject button all of the cd's will be ejected. A couple of times I had to use another cd to kind of slide underneath the stuck cd to assist with it ejecting while I pressed the eject button.
Feb 24, 2010 | 2001 Lincoln LS
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Stuck cd
press & hold the eject button
Feb 07, 2009 | Alpine CDA-7863 CD Player
CD Eject
Press the Jensen logo button. The panel will drop down. A button inside will eject the CD.
May 26, 2008 | Jensen - CD4010K
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
Nov 30, 2007 | JVC Arsenal KD-AR260
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Gear Head WIRELESS keyboard/Mouse Logo
23 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
brian soufane
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
