Question about Coby 8GB MID7065-8 7" Android 4.0 Tablet
Wifi not opening - Coby 8GB MID7065-8 7" Android 4.0 Tablet
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
My tablet says no connection
Is this your home wifi or in a public place with free wifi?
I public places you always have to open a web page to a new page and accept terms and conditions.
Athome you have to click on your home wifi network name and then add the password in settings.
Oct 07, 2015 | Tablets & eReaders
I am sami from pakistan ...I have Craig tablet CMP741e..I have downloaded some application of battery du saver.....after this my tablet WiFi isn't opening...so what can I do to make WiFi open..??
Try deleting the application first, if that doesn't let you open the wifi try calling this number its their customer support 1-866-321-7191
May 13, 2015 | Tablets & eReaders
How do I access the WiFi Internet Connection With Tablet
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
Why doesnt my wireless connection work on galaxy note 10.1
I dont know about 20.1 however if is 10.1 go to settings>wireless& networks>wifi>turn wifi on>wifi settings and sure you should find the open wifi with strong signal.If you dont have the security code or access code to the available wifi then there is no way.
May 28, 2014 | Samsung Galaxy Note 10.1
I cannot connect to my home wifi I am sitting across the room from my router and have entered the id# and network key. it will show the network with a singnal and then says Not In Range. I am not 5 feet...
that coby kyros are one of the defective tablet opens in market because of the wifi connection. but i got another solution in that! to open, mail me or add me on the facebook to teach you how to open that wifi @ blueblewvlou@Yahoo.com or search me on facebook ronald c delos santos
Jan 26, 2013 | Coby Kyros 716829701508 Tablet PC
Unable to connect to wifi it just says scanning
make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
Android 4.0 Tablet PC
Feb 04, 2012 | Toshiba Thrive Android Tablet
Toshiba thrive wifi connectivity
u search wifi networks ,,should have in the menu wifi connections or add a new network,,do a search for wifi,,a wifi scan,,when new netwrks or signal s appear on there,,,if it says open u can go online,,if passwrd enabled or wep or psk or whatever u cant ,,has to be a open signal,,like mcdonalds,,hotels,,,stuff like that,,drive an d search,,
Dec 23, 2011 | Toshiba Thrive Android Tablet
Coby 8GB MID7065-8 7" Android 4.0 Tablet Logo
15 people viewed this question
Top Coby Tablets & eReaders Experts
Martin Murray
Hardware and...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
