Question about Canon LASER SHOT LBP 3300 Printer
Cannot print both side
We i commend both side the printer cannot accept commend.
Copying without command
Sir/ Madam
I think You Give Lot Of Print Command And Mistakable Turn Off Your Printer Whats Why Whenever You Turn Your HP Printer Connected With Computer It's Start Copying And Printing By It's Self,So I suggest You To Cancel All Print And Copy Commend By Pressing Cancel Button Or Follow The Step On Below URL Link:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5071505&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c02476541-10%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Or
Follow Us For Hear For HP Printer Support
Jan 08, 2014 | 2SToner HP Laserjet Pro M1213nf Printer...
The printer turned off while printing
Sir/Madam
Verify The Brother Machine Is powered On And There Are No Errors
Make Sure Your Brother Machine Is Set As Default Printer
Delete All Printer Previous Already Given Commend
Check The Printer Status
If You Still Facing Problem Then Go to ->
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Jan 08, 2014 | Brother MFC-8860DN Printer
It can not print when giving commend
Check to see if you have a default printer selected . Start > Control Panel > Devices and Printers, right click your printer and select it as default.
Apr 14, 2011 | Computers & Internet
Hi , We're trying to print the file to TLP 2844 using DOS commend : copy test.txt LPT1 , but the printer does not response . We installed the out-box driver and make the driver pointed to LPT1, It...
the only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
Mar 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
I am not able to take the print from tally
to print anything from telly
go to the page you want to print then hit alt+p
on right side hit the button select printer
set your printer in it
hit enter and accept
now you can print from tally.
Mar 05, 2011 | TallyGenicom 2265+ Matrix Printer
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
I have loaded photos on to a memory stick. When i put the memory stick in to the printer it says its an unsupported device. What should i do?
this is meaning that the printer do not support a usb memory stick ..and for to print them you will have to hook the printer to a computer and give the printing commends from it ..or ...try a memory card ..
or ..if you know the the printer supported the usb memory stick before see the format of the pictures to be compatible..
Jun 20, 2010 | Canon SELPHY CP780 Thermal Photo Printer
Need to know how to do two-sided copies
Will depend on what type of printer you are using.
If you are using photo paper the back side will not accept ink. You will have to use a paper that accepts ink on both side.
These are the steps to use if you are printing from Acrobat.
Options such as duplex printing and stapling are controlled by the printer, not by Acrobat. The information for such options is stored in the printer driver and PostScript Printer Description (PPD) file associated with a particular printer. If your print driver supports these features and you are using Windows, you must also make sure the features are enabled.
To enable duplex printing and/or stapling:
  1. Choose Start > Printers And Faxes.
  2. Right-click your printer and choose Printing Preferences.
  3. Click Advanced.
  4. Expand Document Options > Printer Features.
  5. Select the desired options and then choose On from the drop-down menu.
  6. Click OK, and then click OK again to exit the dialog box.
To print duplex on Windows:
  1. Choose File > Print.
  2. Click Properties.
  3. Click the Layout tab.
  4. Make a selection from the Print On Both Sides pane.
  5. Click OK, and then click OK again to print.
Nov 26, 2009 | Office Equipment & Supplies
Spooler system is not running in 1020 laserjethp printer
start button
run
type services.msc
select print spooler
right click and select start
select properties and make sure it is set for automatic
Sep 11, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Canon LASER SHOT LBP 3300 Printer Logo
13 people viewed this question
old marine
old marine
