Question about Transtar Chrysler A500-SE 42RE, 44RE Transmission 2000 - Up Master Rebuild Kit
Transmission problem 42re automatic trans in a dodge truck. Truck warms up for a minute or two pull out of driveway first gear is good, at the very end of second it will kick back down to first and stay their until I let off the gas a little and it will shift right into third. Other times it will catch its self or act like it will kick down for a split second what I mean is the RPM's will go from 2100 to 2400 right before it's about to shift into third and it will shift with out me letting off the gas after words it's like it never happened truck shifts great for the remainder of the drive plenty of power no issues what so ever until the truck is turned off for a few minutes then it will do it again witch led's me in the electrical/sensor/TCM problem. It seems like a kick down issue. Bad band, kick down cable out of adjustment, band adjustment but it's very elusive. New band, kick down cable is adjusted and the band is adjusted, fluid and filter change no metal shavings in pan. No clue what approach next.
SERIOUS ISSUES HERE. Have a '99 dodge dakota 3.9
we can not fix or suggest a fix for unknown things
Mar 13, 2017 | 1999 Dodge Dakota
2001 Dodge ram -2500 automatic. transmission slow to engage, months later started not shifting into 3rd gear, then 1 months later slow to engage into 2nd , now only 1st gear......
sounds like filter could be clogged, if it hasn't been changed in a while. you can try to replace throttle position sencer, it is like your old trans kinkenge system, only now, it is elect. it tells trans when to shift, like your speed sencer on trans doe's. both can make it act like it is.
Jan 10, 2011 | 2001 Dodge Ram 2500 Truck
2000 dodge ram 1500 slt ext cab automatic transmission shifts in first gear but takes a long time
Lack of info, does it take a long time to **** to second gear, or second gear to first, either way you have possible governor pressure issues, or 2nd gear band adjustment, whats the rest of the shits like, throttle cable adjustment, drop the trans pan and look for debris, if you need more help, more info is needed from your end. GOOD LUCK, RDJRP
Oct 03, 2009 | 2000 Dodge Ram 1500 Truck
Possible tranmission slippage??
yes this is a defective trans, u either have a worn out direct clutch or a hydraulic leak inside the trans, u can try changing the fluid and filter it may help, if not you will need to replace the trans.
Oct 02, 2009 | 1993 Ford Ranger SuperCab
What other yrear transmissions will fit in the 95 grand cherokee with the 6cyl besides 95?
42RE: The 42RE four speed automatic transmission was used in 1993.3 to 1998 Jeep Grand Cherokees with 4.0L engines. 46RH: The 46RH four speed automatic transmission was used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines.
May 29, 2009 | 1995 Jeep Grand Cherokee
I have a 1996 dodge ram 1500 5.9 with a transmission problem
Remove and check the trans electrical connector, this sounds like a connector problem, look for green corrosion or loose pins
Mar 11, 2009 | 1996 Dodge Ram 1500 Club Cab
1996 Dodge Ram Pickup Automatic requires shifting in order to run
It sounds like when you had the trans service don't he didn't do something right. He might have put the wrong fluid in. Does the trans make noise? Sounds like the trans is going in your truck.
Mar 09, 2009 | 1996 Dodge Ram
Excess transmission fluid
The easiest way is to pull the line off and put a rubber hose over the connection. Crank the engine over. The best way is to drop the pan and put a new gasket on it and fill it with 4 quarts of fluid. Look at your dipstick, it will tell you whether the truck needs to be in neutral or park to check the fluid.
Jul 07, 2008 | 1991 Dodge Ram 150
Transtar Chrysler A500-SE 42RE, 44RE Transmission 2000 - Up Master Rebuild Kit Logo
447 people viewed this question
Top Transtar Home Experts
john h
Tom Chichester
Are you a Transtar Home Expert? Answer questions, earn points and help others
