5kva ups continue beep sound. because this unit switching on the time ,what reason please tell me
This ups name numeric ups
  • 3,320 Answers
4 Suggested Answers
jvpacoin
  • 91 Answers
SOURCE: relay switching sound
Have you change the battery? Note: Matrix UPS need to be calibrate after changing batteries or reset the Smartcell communication board. to make sure that the UPS would detect that you already replace it with the new battery
Posted on Aug 14, 2009
  • 608 Answers
SOURCE: What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Posted on Apr 25, 2010
SOURCE: numeric ups with fault indication
Please Change Battery or Check the PCB Masfecter
Posted on Jun 17, 2010
Numeric ups
That means the battery in it is probably bad.
Aug 19, 2013 | Car Audio & Video
My fridge beeps intermittanly
Hello, when a fisher and paykel is beeping it is usually beeping due to a door being open or ajar or the switch that interacts with the door closeing being at fault. First check your seals and assure you have no rips or tears in the seal. Secondly you would check the switch that the door closes against usually the small black strip on some of there models. If you need me to bring up your schematic to show where your switch is located message me back your model number of the machine. Also if you have any further questions message me back those as well. Another question for you is if you look on the rear wall of the freezer do you have any frost built up if you did this would be called a defrost issue that your unit was having. Most of the time though the beeping sound is due to the switch for the door shorting and after it does short tells the control that the door is open. I await your reply if you have any further questions and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks,
Rick
Aug 23, 2011 | Fisher and Paykel Refrigerators
I had continue beep sound when I turn on power. Can you help?
Beep sound indicates that the timer is finished and can be stopped by pressing start/stop button, however, it is not normal to hear continuous beep sound upon switching on the unit. Try to check if the timer button is not stuck and or check if you have programmed time.
May 12, 2011 | Star SWB7RB Waffle Maker
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
How many batteries are in pw9125-5kva and which type are they?
Normally they use 20Nos 12V/7Ah batteries. Not sure if your unit is with any custom battery packs or options
May 11, 2010 | Powerware PW9125 5000G HW FC 5KVA 3.5KW...
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Relay switching sound
Jul 30, 2009 | APC Matrix-UPS 5000 UPS System
Numeric ups with fault indication
Oct 14, 2008 | QVS NetStar (UPS650A) UPS System
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
