Question about Canon Pixma Mx432 - Multifunction Fax / Copier / Printer - 5783B002
Entered wrong passcode
I gave my wps name but wrong code
What's my wps pin for a X301 cell phone?
The PIN is set up in the router...you enter it into the phone during wifi setup to be able to access the network. Only you (or the router administrator) knows the router PIN (passcode).
Jan 26, 2016 | Computers & Internet
How do you enable ipad?
If you enter the wrong password six times in a row, you will be locked out forever, but you can follow these steps in this Apple article to restore your iPad. This is a security feature to keep sensitive data out of the wrong hands.
iOS Forgotten passcode or device disabled after entering wrong passcode
Sep 01, 2014 | Apple iPad (16 GB) WiFi Tablet PC
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
Aug 15, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I forget my phone lock code . plz help me
Locked Out, Forgot Lock or Restrictions Passcode, or Need to Restore Your Device 1. iOS - Forgotten passcode or device disabled after entering wrong passcode 2. iPhone, iPad, iPod touch: Wrong
Dec 19, 2013 | Lands Phones
Put in wrong password on the phone too many times, now i cant log in to my google acct on it either, its just stuck at the same spot
What Brand and Type of phone ??..
Phone password or google account password ??..
Im thinking iphone ?
Although a passcode limits your iPhone to authorized use only, protecting your vital personal information, if you forget it, you can't use your phone until you enter the correct code or revert your phone to the default factory status.
Apple provides ways to resolve a forgotten passcode problem and improve the iPhone's security.
Wrong Passcode
When you enable iPhone passcode security, the phone requires you to enter the code to display the home screen.
By default, when this protection feature is enabled, you'll be prompted to enter the passcode to turn on or restart the iPhone, wake it or unlock the screen.
When you enter the wrong passcode, the "Wrong Passcode try again" message appears onscreen.
If you enter the incorrect code too many times, the iPhone will lock automatically and display the "iPhone is disabled, try again in 1 minute" message.
This disabling security feature is designed to protect it from unauthorized tampering.
If you keep entering the incorrect code, the iPhone will be disabled for a longer time.
Restoring iPhone
If you don't remember your passcode, unfortunately, there is no way to retrieve it.
Apple says that the only way to solve passcode problems is to restore the iPhone with iTunes.
Before restoring the phone, downloading and installing the latest version of iTunes will improve connection and decrease the chances of errors.
Unfortunately, restoring the iPhone erases saved content and clears custom settings, so create a backup copy of your files with iTunes before proceeding.
From there, you can restore your iPhone by clicking the "Restore" button on the device's "Summary" tab in iTunes.
When the process completes, you can change the passcode settings.
Changing Passcode Settings
iPhone allows you to not only create a new passcode, but specify the amount of time it should take before the screen locks after inactivity.
You can also specify whether you want to use a simple four-digit passcode or a longer one that can include letters and numbers.
Tapping the "Settings" icon on the home screen will bring up the phone's settings.
From there, tapping "General" and then tapping "Passcode Lock" will bring up the "Passcode Lock" customization screen.
Select the settings you want to use to protect your iPhone. The changes will take effect immediately or when the iPhone turns off.
Tips
After restoring your iPhone, create a passcode you'll remember easily.
While creating a longer passcode can increase the security on your phone, you can forget it easily if you don't write it down and store it in a safe place.
gmail password reset
Open the Web browser on your phone and navigate to gmail.com.
Tap "Can't access your account" located under the "Sign in" button.
Select "I forgot my password" and then click "Reset your password here."
Type your email into the "Email" text box and then type the random captcha into the captcha text box.
An email with your new Gmail password will be sent to your alternate Gmail address.
Follow the directions in the email to reset your password.
Type the new Gmail password into the loin screen on your Droid to unlock the account.
http://www.gmail.com/
Sep 12, 2013 | Dell Computers & Internet
How long i will be block
Did you enter the wrong passcode into your phone? If so it usually states the amount of time you will have to wait to try to unlock your phone again, like 1 minute, 5 minutes, 15 minutes, etc. However if no time is showing up that most likely means you entered the wrong passcode too many times and now you have to call your wireless carrier to get a code from them and reset your PIN or passcode.
Feb 25, 2013 | Cell Phones
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Canon Pixma Mx432 - Multifunction Fax / Copier / Printer - 5783B002 Logo
13 people viewed this question
old marine
old marine
