Question about Asrock P4I45GV P4/845GV/FSB533/A&V&L/Modem/MATX Motherboard (MOTASR20)
I have main p4i45gv and Problem With Detect Modem Zoltrix. i do test other modem.main is detect pci modem please help me ...
  • 255 Answers
HI,
GO TO SETUP AND DISABLE ONBOARD MODEM.
PUT A NEW MODEM (PCI) AND INSTALL IT.. YOUR PROBLEM WILL BE SOLVED.
EHSAN.
Posted on Jun 15, 2009
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
Cannot detect a video card
Hi!
Set your Primary Graphics Adapter to AGP or PCI-E in your computer bios.
Use temporarily your built in motherboard video card device to do this.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 03, 2010 | Asrock 845GV (P4I45GV) Motherboard
My AOpen modem fm56-svv say: NO CARRIER
Assuming you have checked the connection to actually make sure you have dial-tone, you could go into the modem's properties page (Control Panel -> Modems-> Properties) then go into the MODEM tab and make sure to UN-check the box that says "Wait for dial-tone before connecting". Sometime the modems don't detect dial-tone properly.
Sep 03, 2009 | AOpen FM56PX PCI Modem W/Vocie...
MODEM ON HOLD-
is pc showing this modem in control panel under system icon? now try uninstalling Modem and reconnecting it and plug in phone line......if software cant detect it on boot up ...then it sounds like a defective modem.....
Jun 11, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
Sound driver
This is, again, for your sound card problem -> Open 'regedit' (Start -> Run -> type Regedit and press enter), search for 'enum' (Do this by pressing Ctrl+F on your keyboard, and type "enum" and press "find". There should be two occurrences of "enum". Both will have a subfolder called 'HDAudio'.  Delete both HDAudio folders (one may require changing the permissions on it).  At this point you should be able to install the driver. Go to Control Panel, and click on "Add New Hardware". Have Windows search for new hardware. It should detect the audio device as though it has never seen it before, and install the drivers for it. This is actually a sure-fix solution. I think this may work!  As for the other two problems, viz., PCI Modem and USB device, you have to again download the necessary drivers for your motherboard from the internet. Search on Google with "USB Drivers for G31T-M". And since you are using the internet without any hassles on your PC, do not bother about the PCI modem.
Dec 26, 2008 | Computers & Internet
Incompatible modem codec detected, please check your modem card.
incompatible modem codec detected please check your modem
Dec 10, 2008 | Arris SM56 (SM-56-PCI) Modem
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
REMOVED UNAVALABLE-DEVICE [COM1]
remove your modem pci slot & clean the slot then add modem ...setup modem driver auto ..select ...run then go to my network places properties...create a new connection...
setup your dial up modem & use name password then connect net.
Jan 25, 2008 | Microsoft Windows XP Professional for PC
Asrock P4I45GV P4/845GV/FSB533/A&V&L/Modem/MATX Motherboard (MOTASR20) Logo
113 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
