Question about Toys
Unscramble the word CUDTROPS in connection with physics
Unscramble the word LIGNES TRAMELNEPEC an uncombined element replaces that part of a compound.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
'products', 'single', 'replacement'
Posted on Sep 10, 2014
A (n)_________tells what elements make up a compound and the ratios of the atoms of those elements.
It's called a Formula or Formula of a compound.
H2O, NaCl, H2SO4, I believe that's what you're asking about.
H2O is 2 parts Hydrogen to 1 part Oxygen. (Water)
NaCl is 1 part Sodium to 1 part Chlorine (Salt)
H2SO4 is 2 parts hydrogen, 1 part Sulfur, 4 parts Oxygen (Sulfuric acid)
Oct 03, 2016 | The Computers & Internet
How to replace dv7 1130us cpu
When replacing a CPU. Make sure the new CPU is compatible with the device you are trying to upgrade. You are going to enter into the BIOS. Download this PDF manual to be aware on how to get into these settings. http://h10032.www1.hp.com/ctg/Manual/c02642701.pdf
The physical part with replacing the CPU hardware. CAUTION!! DO NOT FORGET TO HAVE THERMAL COMPOUND BEFORE PLACING THE HEAT SINK ON THE CPU. IF YOU DO NOT APPLY THERMAL COMPOUND, THE CPU WILL OVER HEAT AND MAY CAUSE YOUR UPGRADED CPU TO BURN OUT.
LINK TO LEARN HOW TO APPLY THERMAL COMPOUND;
http://www.computerhope.com/jargon/t/thercomp.htm
Good Luck.
Sep 11, 2016 | HP Pavilion dv7-1130us laptop
My dishwasher Goldstar model WDT790My3 water does not get very hot. Lukewarm at best even if I turn on hi-temp wash. Any idea how to fix this?
Your heating element is not functioning. Check the connections to the heating element, physically and electrically, then replace the element if necessary.
Nov 02, 2015 | Dishwashers
Classify the following as elements or compounds 1.1 calcium carbonate 1. 2 neon
Calcium carbonate is a compound consisting of at least calcium and carbon, as the name implies. (The word carbonate also implies oxygen.)
Neon is an element.
Mar 13, 2013 | Cars & Trucks
What is matter?
Matter is a substance that has inertia and occupies physical space. According to modern physics, matter consists of various types of particles, each with mass and size.
The most familiar examples of material particles are the electron, the proton and the neutron. Combinations of these particles form atoms. There are more than 100 different kinds of atoms, each kind constituting a unique chemical element. A combination of atoms forms a molecule. Atoms and/or molecules can join together to form a compound.
Matter can exist in several states, also called phases. The three most common states are known as solid, liquid and gas. A single element or compound of matter might exist in more than one of the three states, depending on the temperature and pressure. Less familiar states of matter include plasma, foam and Bose-Einstein condensate. These states occur under special conditions.
Different kinds of matter can combine to form substances that may not resemble any of the original ingredients. For example, hydrogen (a gaseous element) and oxygen (another gaseous element) combine to form water (a liquid compound at room temperature). The process of such combination is called a chemical reaction. A chemical reaction involves interactions between the electrons of the atoms, but does not affect the nuclei of the atoms.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Apple QuickTime VR Authoring Studio 1.0
Hello, I have a Kenmore Dryer 90 series... We are in a Town house on and the Dryer is on the 2nd floor and the vent goes up vertical for about 12 ft with a 45 then to the roof... my dryer gives off heat...
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
More than likely it is the heating element.Remove the front lower panel.While the dryer is running look inside at the bottom,if the element is getting hot you will be able to see it.If the element is not hot,replace it.
May 13, 2011 | Dryers
Mon ecran hp compaq nx 7010 affiche des lignes blanches et lorsque je le branche sur ecran externe ok
What is happening to your laptop is the power line connecting some row of pixels is failing so only partial colors are showing up causing the white lines. Usually screen replacement is the only answer to fix it and you may find cheaper LCD replacements on Ebay or Amazon.
Qu'est-ce qui se passe ? votre ordinateur portable est la ligne reliant certains rang?e de pixels est un ?chec alors que les couleurs sont partielle montrant par causer les lignes blanches. Habituellement remplacement d'?cran est la seule r?ponse pour le r?parer et vous pouvez trouver moins cher remplacements LCD sur Ebay ou Amazon.
Feb 14, 2011 | HP Compaq Business nx7010 Notebook
Difference between covalent and ionic compound
In general, the most common covalent compounds do not contain a metal as one of its constituent elements. So, with few exceptions to be mentioned momentarily, if you do not see a metal atom in a formula for a compound, it is probably the formula for a covalent compound. (An exception to this is butyl lithium, BuLi of the class of organometallic compounds, which have very little ionic character, even though they contain an ion.)
Most Ionic compounds contain at least one positively charged metal atom, such as NaCl. The metal is sodium as its positively charged ion, Na+. (There are exceptions to this rule. For example, NH4Cl, ammonium chloride, is an ionic compound, containing the ions, NH4+ and Cl-.)
Suggestion: Memorize the common elements and what ions they can form. Study atomic structure and quantum mechanics theory, the aufbau theory, the major trends of the periodic theory, which will give you a systematic way to estimate or predict the ions and the charges of many of the elements. Knowing the trends and patterns in the periodic table will allow you to easily recognize which elements are metals and which are nonmetals. This knowledge, combined with the rules given above in paragraphs one and two, will empower you to distinguish between covalent and ionic compounds, because you will be able to recognize when a compound contains metals or only nonmetals.
Aug 20, 2010 | Scientific Explorer My First Chemistry Kit
\do you have the electrical connection diagram for the top oven grill element for a Belling D841 cooker?
Generally, grill elements have only two connections and they go to the main power switch controlling the oven.  Usually, there is a diagram pasted on the rear panel of ovens or just inside the control panel cover.  If you think the element is bad, remove it and test it with an ohm meter.  If it is 'open' replace it.  If it is not physically damaged or shows an ohm reading, it is likely good.
If the question is the connections, cut the power and visually inspect then trace the switch with the diagram.  Look for corroded contacts where the element is plugged in.  If the unit uses a relay...electronics...those may and do fail.  Sometimes, you can get a similar replacement unit without getting a circuit board or find a rebuilder.
Dec 04, 2008 | Belling Kitchen Ranges
Toys Logo
76 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
