Question about iRiver Story HD
Connection problem cannot connect to Google books there is a padlock on my screen
My view sonic projector continues to search for source when connected to my Samsung and acre chrome books but works perfectly with my dell laptop. Why? I'm using a star tech adapter.
you may need to switch the screen display setting to either duplicate or extended .
https://support.google.com/chromebook/answer/1060909?hl=en
http://www.chromestory.com/2013/05/how-to-manage-external-displays-connected-to-your-chromebook/
Aug 23, 2015 | ViewSonic Office Equipment & Supplies
How do I unlock my ipad 4?
The term "unlocking" when it comes to iPad means either having a password to access the device, or a process to access and change the underlying operating system. The padlock icon doesn't have anything to do with WiFi. Also, if you cannot connect to WiFi, you cannot get to Facebook, Google, or anywhere else on the Internet, in the same way that if you car wont' start, you can't go to work or your buddy's house. Your root problem isn't that your car won't go to your friend's house, it's that it won't start. SO, please re-ask the question with specifics of your root problem, which is you can't connect to WiFi. Do you know the password for your WiFi router? Can you see it listed in the wireless networks? Do you not know how to connect to WiFi in the first place?
Sep 13, 2014 | Apple iPad Wi-Fi + 3G - Tablet - iOS 4 -...
My acer laptop 7720-6569 wont connect to my wireless router it shows a padlock symbol
Try resetting the router and then type in your password on your browser.
Sep 09, 2014 | Computers & Internet
Padlock on my netgear is on
Even though it's locked down you should still be able to connect locally. You may need to use a cable. Once logged into the router you can access the settings to allow access.
Feb 09, 2014 | NetGear WNR1000 Router
Oops! Google Chrome could not connect to www.facebook.com, but in other site i can connect,only face book i can't connect, what's the prob??
It might be due to problem in facebook server. Sometimes the server for little time that's why website can't be opened.
Also try to optimize browser by clearing history, empty cache, remove unwanted tool-bars and Add-ons.
Also update flash player and java.
For an instant fix i would suggest to use PC optimizer having feature of Internet Optimizer like Intel Software partner Reginout.
Dec 01, 2012 | Google Chrome
I cannot connect internet using my dsi xl but i have a wifi connection in mya house
go to the Nintendo Wi-Fi Connection Settings area within the game, then pick one of the network "slots" so your game will remember how you've configured it.You'll have a couple of different connection options at that point, but the easiest is to let the Nintendo DS unit do all the work: choose "Search for an Access Point":
nintendo-ds-wifi-connection.pngNow, hopefully, you'll be able to see your wireless network (or perhaps more than one). The easiest to work with is an open network, which is indicated as a blue padlock that's open. There are also red padlocks (if your system uses WEP protection) and grey padlocks (which are bad news: the Nintendo DS can't work with the security system on that particular unit, probably WPA security).
nintendo-ds-padlock-icons.pngIf you have an open network, just click "OK" and it should work just fine! If it's a red padlock, it'll prompt you for a password: you'll need to know the password of the wireless access point you're using to get past that. If it's grey, well, try finding an open network somewhere else you can use.
May 13, 2011 | Nintendo Dsi XL
I need to download music and there is no file for
Using XP, the player should be detected through the USB port of the computer as a removable disk [also called MSC device].
note:
Before disconnecting the player, always go through the icon "Safely remove hardware" in the right corner below of the computer screen, to keep the player free from data loss or data faillure.
First prepare the player before connection / check normal working of the player:
0. Player NOT connected to the computer
1. Switch the player ON using the >| button
2. Check the HOLD icon in the display: padlock should be OFF
3. When the padlock shows up, unlock the player: slide the HOLD switch to the left: padlock should not show in the display now.
4. Switch the player OFF, holding the >| for about 3 seconds.
When the player should not behave normal, perform a RESET.
0. Disconnect the player if connected to a computer.
1. Remove the battery from the player and leave it out for 10 seconds.
2. Replace the battery.
3. Power ON the player with the >| button and see if the player works normally.
4. Switch OFF the player, holding the >| button for 3 seconds.
How to check the detection of the MSC device on your computer:
0. Player Normal Functioning, NOT connected, NOT locked and switched OFF.
1. Explore 'My Computer': click start in the left corner below of the computer screen and select 'My Computer'.
2. Connect the MP300 to a USB port; detection may take some time.
3. Look on the computer screen if a new removable disk shows up in the explorer overview, coming up with a new drive letter.
4. Now you should be able to put music onto the player, showing up as a removable disk with the new drive letter: use 'copy and paste' or 'drag and drop' method for music transfers.
note:
When no new drive letter shows up, try another USB port.
Connect directly to the computer, not through a hub.
If you need more help, tell me at what point connecting or transferring fails in this thread.
There's also a software program called Coby Media Manager that can be used for detection or transfers. Coby Media Manager is based on MTP connection mode.
Need help for this ? Write your comment in this thread.
May 28, 2010 | Coby MP300 MP3 Player
Locked symbol on TV screen
in the remote for your telly there should be a button marked 'display' or 'disp' or a small square with + sign to it--when you have that padlock on the screen just press and hold that button for 5 seconds, that should unlock your tv
Apr 21, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
iRiver Story HD Logo
51 people viewed this question
Top iRiver Computers & Internet Experts
David Payne
David Payne
Are you an iRiver Computer and Internet Expert? Answer questions, earn points and help others
