Question about Dell B1265DFW Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 29 ppm Mono Print - 14 ipm Mono Print ISO - 1200 x 1200 dpi Print - 29 cpm Mono Copy - 14 ipm Mono Copy ISO - 1200 dpi Optical Scan
Printer goes offline
Why does the printer just go offline?
HP LASERJET P1606DN goes to offline
Happened on our print server this morning for the first time. We have 4 of 1606dn in our organization. Reset the print spooler and that brought it out of offline mode
Jan 09, 2012 | HEWLETT-PACKARD LASERJET PRO P1606DN...
PRINTER GOES OFFLINE
cheak printer connection is proper & paper setting is proper then still printer is offline may be a problem of sensor or datacable give me a status reply
Apr 19, 2011 | Dell 1815dn All-In-One Laser Printer
I have and Canon iR3570 and when SNMP is disabled the printer goes offline and network printing ends. Enable SNMP and change the default community to something more secure and printer goes offline and...
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
Aug 31, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Printer goes offline but is pingable on Network
I would see what kind of data is being sent to the printer. If the spooler is trying to send some data to the printer that is outside of its limits, even a page break missing, it will do this. Also see how much data it is trying to send to the printer. If it overwhelms the printer, it will just give up until the spooler stops sending requests.
Jun 28, 2010 | SATO CT400 Thermal Label Printer
Printer going offline
unplug the printer's usb cable from computer then re-insert, leave printer switched on during process
Jan 28, 2010 | HP OfficeJet 4315 All-In-One InkJet...
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer offline? won't print
please go to start menu, select printers and faxes or control panel to select printers and faxes open it, right click on your printer and scroll down to select use printer offline. then u are safe to print start ur printing. dont forget to rate me when it works am sure it will work. thanks
Jul 17, 2009 | Brother HL-2040 Laser Printer
Printer is offline
Press the most left button at the printer front panel.
May 06, 2009 | OKI Pacemark 3410 Matrix Printer
Dell B1265DFW Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 29 ppm Mono Print - 14 ipm Mono Print ISO - 1200 x 1200 dpi Print - 29 cpm Mono Copy - 14 ipm Mono Copy ISO - 1200 dpi Optical Scan Logo
164 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
