Question about Lincoln Electrical Supplies
Lincoln 305g runs at a very high idle and continues to gain as the engine runs
Excessive high idle and will not idle down
  • 3 Answers
SOURCE: Idle is very very High
Check under the hood for any small vacuum hoses that are broken or disconnected. You will find a lot of small hoses! Most high idle problems are the result of a vacuum leak. Try idling the engine and spray short bursts of WD40 in different areas under the hood. If the engine idles lower when the stuff is sprayed in an area, that is more than likely where your leak is. Don't go overboard with the WD40, just short bursts.
Posted on Oct 27, 2008
  • 44 Answers
SOURCE: engine idle/running speeds sometimes excessive
You have a throttle problem (it gets stuck) take it to a mechanic and have it cleaned and greased up and that should solve your problem.
Posted on Apr 18, 2009
  • 4 Answers
SOURCE: engine idle too high
no, there is no idle screw on them if it is fuel injected. although you could try changing the idle air speed sensor
Posted on Apr 28, 2009
jryan11kc343
  • 19 Answers
SOURCE: Engine idling high in park. Will not start until
check your IDLER
Posted on Jul 11, 2009
  • 9 Answers
SOURCE: 2001 LINCOLN LS V6 - ROUGH IDLE / SOMETIMES STALLING.
Very common problem is about a dime size hole wearing in the rubber elbow on the PCV valve located on the driver side rear of the intake manifold.
Posted on Oct 13, 2009
Why does it have incorrect idle and hangs on fast idle before dropping down to normal?
Problem With Idle Air Bypass Valve May Cause Engine ...
repairpal.com > Problems > Mercury > Sable
2002 Mercury Sable100,000Visitor. Idle control valve makes the idle high and with foot off the accelerator car runs at 40-45 MPH. I disconnected the electrical ...
Aug 07, 2015 | Lincoln Navigator Cars & Trucks
I have a Lincoln Ranger 8 with an Onan Engine. When started the engine runs at an EXTREME RPM. What causes this?
Check movement of the governor arm without it running. You should be able to move it by hand. If it is stuck, it could be the idle solenoid, or possibly something else more major.
Feb 26, 2015 | Lincoln Welding Tools
Lincoln 305g kick out breaker with just 4.5 inch grinder
Have you tried another grinder, or a heater is a good test.
Could be a weak breaker. I use a 1500 watt heater to test outlets with.
Feb 10, 2015 | Lincoln Ranger 305g Welder Generator...
Engine oil leaks out the gasket between cases how will i repair
Two options here:
1) The one i will suggest... send it to an authorized repair shop. Check with your local welding shop/store (Praxair has direct connection with the anywhere), they will ship it down to an authorized dealer.
2) If you are a mechanic or know how to change head gaskets, then take model and serial number of your engine (p.e.Kohler, onan or honda) and go to a autoparts shop and ask for the gasket, then just replace it.
Feb 06, 2011 | Lincoln Ranger 305g Welder Generator...
When i crank my car my engine idles high what causes this problem?
Sounds as if it is just your choke. As long as the vehicle idles down after warming up you are fine . But if it continues to idle high you will need to have the idle adjusted or your choke is bad/
Dec 27, 2010 | 1995 Lincoln Continental
I have a 305g machine runs gen works i do not get any read out from the displays
If it is a digital, you need top replace it. They burn pretty easy with overloads.
Dec 24, 2010 | Lincoln Ranger 305g Welder Generator...
What size battery goes in a 305g?
Group 58 battery with 435 cold cranking amps. Page 3 in pdf manual.
Here is a pdf manual site for your welder...
http://content.lincolnelectric.com/pdfs/products/literature/e6117.pdf
Mar 05, 2010 | Lincoln Electric Ranger 305G K1726-4...
Car starts fine but runs at very high idle &
check your TPS sensor
throttle position sensor
Jan 29, 2010 | 1989 Lincoln Town Car
94 Lincoln TC engine stalls when slowing/stopping
Most common cause of stalling for Lincolns in that era is the TPS (Throttle Position Sensor). It regulates fuel mixture, idle speed etc. A bad TPS will usually act up in one of two ways:
  1. When cold, car continually stalls
  2. When warm, car stalls when slowing down (especially if AC is on)
As far as valve cover oil leak, it's a problem that should be addressed to keep oil from fouling your spark plugs but highly unlikely to be the cause of your stalling problem. Hope this answers your question. All the best.
Greg
Jun 16, 2009 | 1994 Lincoln Town Car
Electrical Supplies Logo
26 people viewed this question
Top Lincoln Electrical Supplies Experts
 Kenneth
Kenneth
John Trevino
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
