Question about Bosch Water Heaters
Bosch microswitch water heaters
Microswitch
Pilot does not ignite?
Look for the pattern of flashing lights when it fails after you turn the power off/on. Then look at the wiring diagram / instructions on the inside of the panel. The flah pattern should be listed. For example, two green flashes and pause, repeating may mean that the exhaust flow is not sufficient, or another flash pattern may indicate pilot is not lighting.
Likely ly a pressure switch is bad or exhaust is blocked.
May 17, 2015 | Water Water Heaters
No clicking sound
When you do not hear clicking the first thing to check is to the check the microswitch. See my answer on this question: http://www.fixya.com/support/t9769963-bosch_model
Apr 22, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
I have a Bosch 125x NG tankless with no power light. I have replaced the batteries. This happen just after the hot water supply line burst and spewed water up into the heater. Im thinking this was caused...
Sounds like the watervalve was never serviced. It will stick if its not serviced every 3-5 years according to the manual. If it sticks, it can keep your burners on after waterflow, and overheat the water still in the exchanger. This can cause plastic/pvc/pex to swell and burst. Thats why any machine says to have only metal lines connected for min of 3 feet.
Since it got wet, you may have to replace your control box as well, but at least maintain your watervalve and recalibrate your microswitch. Those last 2 may be your only issues.
Nov 02, 2013 | Bosch & Tankless LP Hot Water Heater
AE-9.5 Bosch Tankless Water heater - no manuel or installation instructions
This is a "point of service" tankless water heater that was manufactured by BOSCH. BOSCH is now Bosch-Climate.us. Technical support is available at 866-330-2729. P.S. check this site: http://tanklesswaterheaterz.com/bosch-ae-9-5-powerstar-1-5-gpm-point-of-use-indoor-tankless-electric-water-heater-reviews/
Feb 02, 2013 | Bosch AE-9.5 Electric PowerStar PowerStar...
I can no longer hear the clicking on the ignition therefore there is no longer a flame to heat the water. Everything else seems to be working fine.
If there is not a clicking sound, it almost always means the main ignition or control unit (box with red and green lights and wires coming from it) is not getting the supply voltage. The voltage is supplied by a generator that is getting energy from the flow of water (the "hydro generator"). First disconnect the wire connector at the hydogenerator and check the voltage while water is running. The manual says you should read 1.6 VAC (I read 2.5 VAC). Make sure your voltage reader is on AC, not DC. If you have at least something like 1 VAC, then the next thing to check is the "microswitch" that allows the hydro generator voltage to reach the ignition unit. To check it, disconnect the other wire connector that is on the black wire coming from the hydrogenerator that is closer to the ignition unit. Then with the water running, stick a small screwdriver in the male plug side to short the two wires in order to bypass the microswitch (per Bosch tech support instructions). You should now here clicking and see the unit work. This is what happened with me and tech support said I needed to order a new microswitch and gave me a part number and telephone. But don't stop reading here. You can see the microswitch when looking up at the underneath of the unit. It's a small white 1x1 inch box-like shape held by 1 screw. After removing it, I noticed the microswitch had a removable cover (which is strange for a switch) and opened it to discover the internal switch can actually move inside because it "automatically adjusts" itself when it is first put in (it stays more firmly, but not rigidly in place when the cover is on). So you can mess up when putting it in. Don't bump it. It can easily get out of its working range of motion, which is why mine stopped working: it was a bad design to use this type switch in this application. So I slide the internal switch back close to the spring side ("default" position), put the cover back on, carefulyl screwed it in place, and now it works.
The purpose of the mechanical microswitch is to not allow the hydroenerator voltage to the ignition unit unless the "pushrod" has opened the main gas supply. It prevents clicking if there is no supply gas, so it is not needed (you can electrically bypass it with a splice) if everything else is working fine. But don't blame me if you do this and for some reason it ruins the more expensive ignition unit. The microswitch is turned on by the pushrod when the pushrod leaves it's default position. The the pushrod moves only about 2 to 3 mm when you turn on the water. You can see the pushrod when you unscrew the microswitch, and you can watch it move. The problem is that the microswitch mounting is not precise enough for the small pushrod movement and the pushrod's default position can change with age of the diaphragm or change in the grease. So their automatically adjusting microswitch that makes up for lack of precision in design and pushrod movement can stop working when the pushrod changes position. My unit was 2 years old.
Sep 05, 2011 | Bosch 1600H NG AquaStar 4.3 GPM Indoor...
I have a Bosch Model GWH 1600 H tankless water heater. I have had issues with it since I installed it 2 years ago or should say had it installed.Yesterday I could not get it to ignite or light manually. I...
Igniter can be ordered, but that may or may not be the issue.
Your tankless unit -and- plumbing system need total check-up by trained service technician.
Open following links for Bosch troubleshooting resources including contact Bosch, manuals, error codes, water flow etc.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Check electrical outlet with circuit analyzer to make sure polarity is correct.
Typically, gas water heaters, and especially tankless water heaters require yearly maintenance by service technician who can check the gas pressure and supply, venting, electrical connections, PC board, sensors, burner orifices and igniter parts are clean and positioned correctly, vent is draining correctly and not dripping back into combustion chamber, correct temperature is achievable, incoming water temperature is not too cold for temp setting, proper incoming air supply, adequate air supply, no chemicals stored in air supply pathway, filters are clean, plumbing check valves, mixing valves, pressure valves etc are permitting one-way flow of hot water, water is softened to less than 11 grains hardness, water is filtered and not dirty, aerators and other faucet parts are clean and support water flow necessary to activate burner.
Jul 15, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Aquastar gwh 1600 h igniter fails clicks does not spark
Mar 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Hello. I have a Bosch WR-430. It has been working well until recently. (6 years). A few days ago, I noticed that the pilot was not lighting everytime. The spark would spark, but the pilot would not...
Hi, Please do massive / longer bleed on/off for several time and get it retry. If problem still persist, I worry you have problem on your controller and need repairing at dealer.
Regards, Jay
Jan 22, 2011 | Bosch & Tankless Water Heater
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
23 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
