Question about Randell 2020F Reach-In Freezer, 2-section, self-contained refrigera"
My freezer is flashing P2 - what does this mean?
The display showing the temperature is flashing the temperature and then "P2" and then temperature and so on. What does the P2 mean?
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
STOPPED RUNNING
Hello Warner, thank you for your post!
Typically when a freezer displays "OFF" it means that the temperature control is in the off position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try re-activating your freezer by pressing the UP arrow until display shows "4" or desired setting. If the issue persists, then the freezer could possibly be experiencing a communication issue with the control board, temperature control or a potential wiring failure. At this point, I suggest reaching out to an appliance expert who is best equipped to pinpoint the exact problem.
Best of luck!
Feb 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer indicator
Good Afternoon Larry, thank you for allowing me to assist you!
I understand your freezer is showing "OFF". This typically means that the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try reactivating the freezer by pressing the UP arrow until the display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
I hope this proves to be helpful to you.
Jan 06, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire freezer display flashing of and ff. I can't get it to do anything else.
Hello Aaron, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating your freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Nov 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Randell 2020F Reach-In Freezer, 2-section, self-contained refrigera" Logo
78 people viewed this question
Top Randell Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Randell Freezer Expert? Answer questions, earn points and help others
