Question about Kodak i1220 Pass-Through Scanner
Scanner fails to format image
Scanner was reinstalled in computer after it crashed. it now saws scanner failed to format when I scan documents
    New Friend:
  • 31 Answers
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Posted on Apr 15, 2014
    New Friend:
Very Helpful!
Posted on Nov 18, 2016
Copy goes through scanner but comes out blank on screen. I know it's being inserted correctly (not backwards).
I'm a 99% sure that you've got some hardware problem with your scanner, probably some internal sensor it has is failing. Just as a test, you should install this scanner on another computer - ask a friend for help - test it and if failure persists you have two options: Live with the failure until it goes worst and stops scanning at all or you take it now to repair.
On the other hand, if it works ok on another computer, try to uninstall it completely and reinstall it.
Dec 22, 2014 | Fujitsu fi-6130z - Document scanner -...
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
How do it get it to scan from my printer to my computer. It says "Scan Error. Try scan from computer or see documentation. Press OK I did and it just shows the three options. Please help TY
Generally there are two ways to scan.
1. Your printer has a management program which controls most operations. On a Lexmark, it is the Lexmark Imaging Studio. Select scan there.
2. Your document software, Word, Photoshop, etc, can start the scanner. Usually under File, look for Acquire....Import....Twain.... Your printer/scanner should be listed. Select and start scanning.
If all this fails, you may be missing a driver, get them from your printers MFG web site.
good luck
Nov 16, 2009 | Computers & Internet
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The documents are scanned but dont appear on later inspection, or if they do they are just a horizontal line across the middle
Try reinstalling the driver software. If the problem still persists, run scandisk or reinstall OS.
S. Mohan
Aug 21, 2008 | Canon DR-9080C Path-Through Scanner
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Scan in word 2007 documents using vista
From Word 2007 Help:
The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
Mar 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
Kodak i1220 Pass-Through Scanner Logo
2,440 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
