Question about Miele 30 in. KM443 Electric Cooktop
Unable to turn lock off, system comes on then off in 5 seconds
I turn the system on each element lights up with different numerals then clicks off, unable to unlock the system
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 | Cooktops
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
How do I unlock my Dacor cooktop
When your Dacor cooktop is locked, there will be a red light lit above the Dacor emblem located under your cooktop controls.
If you see this light, pressing the Dacor emblem for three seconds will turn it off and unlock your range. Pressing it again for three seconds will again lock your range and turn the light back on.
Another fun thing about that Dacor emblem is that if one or more of your elements are lit, tapping it twice in quick succession will turn off all elements.
Sep 04, 2011 | Dacor Millennia ETT304 Electric Cooktop
Hello, i cannot turn the child lock off on my stovetop. this is a brand new problem as i do know how to normally turn the lock off.
Not sure if this is for your exact model but here is a link to an Online User's Manual for one similar:
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KECC508RPS_Use%20and%20Care_EN.pdf
Just click on the link (underlined and highlighted text) with your mouse and a new browser window will automatically open to show you the information in the manual.
On page 7, it reads as follows:
To Lock Cooktop: Touch and hold the CONTROL LOCK/
ALL OFF keypad for 5 seconds. After 5 seconds, CONTROL
LOCK will glow red, indicating that the cooktop touch controls
are in the lockout position.
To Unlock Cooktop: Touch and hold the CONTROL LOCK/
If you have any questions or require further assistance just comment back to this page and I will endeavour to help.
Good luck and please click on the 4 Thumbs Up rating icon if this was at all helpful.
Thank you very much.
Joe.
Feb 17, 2011 | KitchenAid Cooktops
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Nov 15, 2010 | GE Profile JP930 Electric Cooktop
The red light is on above the dacor name but nothing will go on.
this may be due to your child lock function, depress lock function(for whatever use and care manual says) and it may release to open functions.
Sep 30, 2010 | Dacor Millennia ETT304 Electric Cooktop
I have the 5 element induction cooktop with no
Call 1 800 442 1111 Its whirlpool they own kitchenaid. they can find a local tech for you
Dec 12, 2009 | Cooktops
I can't turn on the range. it has a light that says all off control lock
From the manual, page 7:
Sep 24, 2009 | KitchenAid 30 in. KECC506R Electric...
New Whirlpool Cooktop Problem...Maybe.
The function 3 element are normal / depend to the intensity adjustment / the small 4th element are set for pre heating w/out burning , try to sdjust in lower adjusment or ann switch for pre heating.
Dec 04, 2007 | Cooktops
Miele 30 in. KM443 Electric Cooktop Logo
77 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
