Question about Jacuzzi Perfecta Almond 1.6 GPF Round 2-Piece Toilet EZ33958
Need tank replacement
Need tank by itself
Problems getting gas from gas tank to my outboard 15 HP 4 stroke Mercury.
need to clarify your statements
you say-- have replaced flexible lines from the tank to the engine --replaced the primer bulb
well that is all the rubber hoses from the tank to the pump on the engine
Then you further state only parts not replaced are the connections between the
gas tank and the motor and the tank itself
Well that connection is the rubber hoses that you stated were already replaced
So this may help rubber in outboard motors rots internally so replace all rubber from the tank to the motor, overhaul the fuel pump on the motor and all the rubber hoses from the pump to the carby/s
the primer bulb will not pump fuel if the tank vent is not open so that is one reason you feel like it is pumping air when priming
best advice is --no e-mix fuels to used on out board engines
Sep 18, 2017 | HP Garden
Where is the fuel pressure sensor located on a 2002 GMC Sierra 1500 4X4?
The fuel tank pressure sensor on a 1999 GMC Sierra is located on the top of the fuel tank on the fuel pump itself. Most say that you need to drop the fuel tank to replace it but if you have access to a lift you can replace it without removing the fuel tank. By removing the rear U joint straps and moving the driveshaft to the side you can see and access the sensor for replacement. Chock wheels to prevent movement of the vehicle after driveshaft is disconnected.
Apr 11, 2013 | GMC Sierra Cars & Trucks
Replace fuel pump
It should be on top of the fuel tank itself. You will have to drain your gas tank, remove the tank and then replace the pump and put it back together.
Sep 20, 2012 | 1994 Nissan Pickup
Compressor is OK but tank may need replacement
have you tried to find a welder to repair the tank?
Aug 04, 2012 | Porter Cable Air Tools & Compressors
Gas tank fuel level sensor location
the fuel sending unit is located on the fuel pump itself,located on the side of your fuel pump inside of the gas tank itself.you'll need to replace the entire fuel pump in order to solve fuel level issues. the fuel tank will have to come out,and then the fuel pump removed and replaced.it really stinks to have a bad fuel guage reading false,only to find out that the entire fuel pump has to be replaced to solve a false reading . feel free to call your local autozone or advance autoparts store for details. but here is a hint" the more fuel in your tank at the time of replacement of the fuel pump,the more expensive it will be.due to the fuel tank being "heavy" that has been my expereince so far. good luck and thank you for choosing fixya.com
Mar 27, 2011 | 1996 Chevrolet C1500
My 2000 Frontier v6 has a small leak or 2 at the top of the gas tank. can this be repaired or do I need a new tank? thanks
If the tank itself is leaking, replace the tank. If it is a seal for the fuel pump or other, replace the seal.
Jun 10, 2009 | 2001 Nissan Frontier Crew Cab
Fuel tank switch quit working and fuel gauge tacks out full now. Can't find a thing on it in the chilton's manual. Any help would be appreciated.
if you have replaced the switch itself, check the connection leading to the tank. if there is no loose wires or connectors then chances are that either there is a a bad connector to the float inside the tank, or the float itself is faulty. also if you flip the switch and the gauge still shows no change the it is the gauge it self that needs replacing because the odds of both flo9ats being faulty is very slim to none
Apr 17, 2009 | 1979 Chevrolet C/K 3500
Hi my gas niddle stays full all the time can you help please scott
sounds like the sender unit is done ,unfortunately this is located in the tank itself you need to have tank drained to drop tank out and replace sender unit easy job but time consuming
Jul 20, 2008 | Chevrolet Camaro Cars & Trucks
Jacuzzi Perfecta Almond 1.6 GPF Round 2-Piece Toilet EZ33958 Logo
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
