Copy is not clear. Seeing carbon smudges on copy
  • 313 Answers
If the carbon smudges are dry and can be removed check the condition of the fuser it could be damaged or a build up of toner stopping it from fusing to paper.. you could also take the drum / dev units out and see if ther is a build up of toner in these units vac off or blow waste toner off..do not touch the drum surface though cause this will really ruin your day!!!good luck A
Posted on Jun 15, 2009
D. ?There are five (main) components to an (e-mail) message besides the message box itself: from, to, cc, bcc, and subject.
Yes.... that's right. but what is your question?
If you're asking about CC - that means carbon copy. It comes from the days of typewriters when a sheet of carbon paper was inserted between two pages inserted into in a typewriter.
The impact of the inked letters wrote on the top sheet, and the impact also caused the carbon paper to transfer the same text onto the second sheet of paper. Hence 'Carbon Copy'.
BCC means 'Blind Carbon Copy'.
If you send an email to somebody but include a second person as 'CC' the person who receives the CC is aware that the email was sent to somebody else as well.
if you add somebody as BCC - Blind Carbon Copy - that person receiving it is unaware the email was also sent to another recipient.
Apr 16, 2017 | The Computers & Internet
A smudge appears on every copy of my photocopies. Why?
please clean the glass and laser ,otherwise change the drum and blade
Mar 05, 2014 | Toshiba e-Studio 232 Black and White...
When i first start my copies on my brother dcp 1000 they are clear by the time i get to copy 20 their are dark ink smudges on the paper. It seems when the copier starts heating up they smudges happen. I...
replace the drum,
( if you have used correct toner for refill because some time it happens if two different type of toner mixed up hence assuming that you have select gud toner).
vote me if found helpful.
Aug 17, 2011 | Brother DCP 1000 All-In-One Laser Printer
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Copy is smearing from top to bottom on left side of paper about 1 inch wide.
The print in the smudged area, does it wipe off the page like not fused well to the paper. Do you also have a crinkling noise, if so the sleeve in the fixing assembly has torn. You may still have it under warranty with canon and can get it fixed for free.
Good luck
Bob
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Dell all-in-one problem
Check if you are using refilled cartridges and have any leaks (may need a cleaning) or if the paper has been exposed to high humidity. You can test by running a few sheets through from a new **** of paper and seeing if the smudging goes away.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
I purchased "tasty planet" from reflective entertainment inc but have not received my activation code. i have reaplied for it but still dont have it. keep being told item no:eabzrprdk46cvr3xej937...
That's great, but why are you asking anyone else than Paypal or Reflective Entertainment what the problem is?  If you want codez this isn't the site.  Patently, PayPal takes a long time to settle for merchants; doublecheck your browser history of the purchase to cc with PayPal as an issue if you still have no code (check y'r spam folder, etc.) and give Reflective a carbon copy, expecting them to make good.  I mean, especially send Reflective a copy of the PayPal screen with personal details redacted (smudged out.) And this ain't a PC Desktop problem, but I'd put it down under Software/Tasty Planet....
Jul 27, 2008 | Computers & Internet
Actually a Canon PC-65, problem follow-up
canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
Jan 03, 2008 | Canon C130F Black and White Copier
PC-65 (Canon copier)
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Jan 02, 2008 | Canon C130F Black and White Copier
87 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
