Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Ul Unlovely won't spin out
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Im getting a uL message on my spin cycle and I dont know why.
The "uL" message stands for "unbalanced load." Open the lid to the washer and redistribute the load if the "uL" display appears on the appliance.Redistributing the load should correct any imbalances in the washer and allow the washer to turn freely. Close the lid and press "Start" to restart the washer.
Jul 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
10 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
