Question about Learning Curve Toys Thomas the Tank Engine Train and Friends: Water Tower Figure 8 Set
I need a manual for thomas the tank engine track 7404.
I am needing a manual for 7404 thomas the tank engine track.
Need tracks for ride on thomas the tank engine
Ebay would be where I would go for this.
Jan 21, 2013 | RC Thomas the Tank Engine
I inherited a thomas and friends coal mine set. i need owner's manual to see if i have all the pieces and its set-up
the set you're talking about is called the tomy thomas big loader set you can probably find the instructions off google images
Aug 17, 2012 | Tomy Thomas The Tank and Friends Track
I need the instruction manuel for gullane thomas limited 2003
i cant help you because i need the name of this set or engine. All you put down was the licensing info.
Apr 20, 2012 | Tomy Thomas The Tank and Friends Track
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
I was given a thomas train and track set, but did not come with battery or charger. I need to know which ones to buy.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Apr 07, 2010 | Learning Curve Toys Thomas the Tank Engine...
Hi i have a thomas ride on an i need a replacmen battery and i cant get on anywhere
Try searchig E-Bay I normally manage to find any type of battery I have needed. If not research it on GOOGLE you will be able to find lots of suppliers for batteries. I hope this helps.
Oct 31, 2009 | Learning Curve Toys Thomas the Tank Engine...
Joining the tomica world set with the expansion set, need a desig
Steven,
The Fixya website has absolutely nothing to do with Tomy. My recommendation is to direct your question to Tomy directly here:
Contact
Feb 05, 2018 | Tomy Thomas The Tank and Friends Track
Thomas the Tank Engine, Sodor Post Office Train Track
http://www.thomasandfriends.com/usa/news_product_info.asp
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
Robert
Please take a moment to rate this solution thanks
Jan 29, 2009 | Seth Thomas Thomas The Tank Sodor Engine...
Learning Curve Toys Thomas the Tank Engine Train and Friends: Water Tower Figure 8 Set Logo
27 people viewed this question
Top Learning Curve Toys Toys Experts
ray gallant
partimefixer
Level 1 Expert
Tom Chichester
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
