Question about Hodedah Import HI71DR Seven Drawer Jumbo Dresser with Additional Door
I need to put on the drawer slides how do I do that
I need to install the drawer slides how do I do that
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
Cant put drawer back in beko freezer
Drawers usually have stops to prevent them from being removed completely in normal use. You may have to experiment with the empty drawer to find a way to slide it over the stops into the closed position, then slide it open to load it.
Jun 03, 2016 | Beko Refrigerators
I want to reinstall a oven storage drawer on a electric LG oven
I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
Nov 06, 2013 | Kitchen Ranges
How to remove center desk drawer
Some drawers have slides that have latches that have to be manually depressed simultaneously, in ordert to remove the center drawer. Look at the slides and see if there is a button, or possibly a machined strip of metal, that releases a latch that keeps the drawer from falling off the end of the slide.
Sep 17, 2017 | Hal Leonard Music
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Need to remove drawers in Homak tool cabinet
There should be slots in the sides of the drawer slides. Insert a screw driver in the slots and push the tabs in and pull the drawer out that way. To reinstall the drawer just hold the drawer slide and push the drawer past the tabs.
Mar 27, 2011 | Homak Rolling Tool Chest
Desk drawer - slides open
my husband is having trouble installing a kitchen drawer slide--it keeps jumping off track--can anyone help??
Mar 17, 2009 | ACCO Brands Kensington Desktop Comfort...
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Bottom drawer sliding problem
can you pull the drawer up and out to take a look at both?let me know-mike
Oct 01, 2008 | Fisher DD603FCSS Dishwasher
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
Hodedah Import HI71DR Seven Drawer Jumbo Dresser with Additional Door Logo
78 people viewed this question
Top Hodedah Import Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Hodedah Import Furniture Expert? Answer questions, earn points and help others
