Question about Dometic RM2652 Refrigerator
How to reset refrigerator
I am just wanting to know how to reset the fridge. The lights come on inside it just will not cool anything. I need a reset diagram or reset pins jumper wire etc....
    Sergeant:
  • 233 Answers
It is a refrigerator not a circuit breaker.
If you adjust the thermostat to a cooler number and wait say 12 hours.
And it does not cool, the condenser may not be working or the unit has lost some/all refrigerant. (gas that is circulated and provides the cooling) . You can check the coils on the back and make sure these are clean. Call and investigate pricing to add the freon and check for leaks. Also have them see if the condensing unit may be the culprit if the refrigeration gas and oil are ok.
Hope this helps
Posted on Mar 28, 2014
My Frigidaire Model # FRS26LF7DS7 is not cooling!
Could be a few problems. What I would do is check to see if the compresser is running by pulling out the fridge and pulling the back panel off and putting your hand on the compresser. If it Is vibrating then it is running. If it is not vibrating but very hot then the compresser is dead and needs to be replaced. If the compresser Is cool and not running I would say the thermostat inside the fridge is dead(bad contacts in the control). If the compresser is running but no cooling, the cap tube which is the metering device for the refrigerant into the freezer evaperator could be plugged off. Or if none of the lines off of the compresser are hot or cold then the valves inside the compresser are gone and compresser needs to be replaced hope this helps
Sep 06, 2012 | Frigidaire FFHT1817L Top Freezer...
Hi, i have an Electrolux ER7198S side-by-side fridge. there are not cooling enough.. someday cool someday not, may i know why and how to slove the problem? thanks
Make sure there is about 3 inches of clearance behind the fridge from the wall. Move the fridge away and check that the condenser coils are not covered heavily in dust. This can reduce the fridges efficiency.
You may also want to open and check the inside panel of the fridge to observe the evaporator coils and defrost tubes. If those tubes are burnt out (they are basically long light bulbs) you may get a build up of frost and ice that stops the flow of air thought the evaporator. This will cause the fridge to become warmer, up until complete failure.
Jun 01, 2012 | Refrigerators
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
Swapped my ma785r board to a new case and need the pin layout for power switch and reset switch
ok i dont hqave it but as i buld a lot of used pcs and new ones its usaly goes like this there is a 9th pin and a tenth one missing next to and in a straght line down the way nest to where the missing pin is is the on of under it is the reset pins next to the reset one is the hdd led and that leaves 1 set of 2 pins left if you want e mail me and ill draw a diagram for you hope this helps
Mar 17, 2010 | Computers & Internet
Not cooling fridge or freezer.
need cooling at the back, unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
I've a Amana ARB1917 and I want to know where is timer defrost ??
The defrost timer for the unit is located under the fridge in front or back. Depends on model. A few put them inside the fridge. Russ
Jul 18, 2009 | Amana ARB1917CSR Bottom Freezer...
Dometic RM2652 Refrigerator Logo
119 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
