Size of belt for grundig rpc 2000
What is the diameter of the belt for the old grundig rpc 2000-2
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: need new belts for Grundig Tape Recorder TK5 1957
Hi there
You can source an entire belt kit to freshen the old girl up from here
It is a German ebay seller, but may well be your best chance for something like this on Grundig product. Good luck with the overhaul, and thanks for using FixYa.
regards Graeme
Posted on Jul 08, 2009
Replace belts on realistic sct-30
I can't tell you how to change the belt on your model though I have changed many belts...
Some belts are fairly straightforward to access and others are more like a torturous route march but once the belt has been accessed, the next problem is identifying the belt cross section and diameter.
Buying a belt from the manufacturer as a spare part is likely to be expensive and often difficult as the trade generally prefers to obtain replacement belts from a general component supplier meaning the manufacturer needn't keep any stock.
Replacement belts are listed in diameter of length size increments and cross section shape and size. If you know the size of belt needed, ordering is easy but belts begin to stretch from day one so measuring the old belt would be useless and using string or a tape around the pulleys also useless.
Typically a new belt of the right size must be stretched to fit around the pulleys - some considerably and some not as much and mostly by how much smaller the new belt needs to be is pure guesswork, consequently it usually pays to order a selection of sizes and choose the one that provides the best result.
Before fitting it is well to remove all traces of residue and oil or grease from the pulleys and to slightly abrade any highly polished driving surfaces with something like Scotchbrite.
Mar 15, 2017 | Audio Players & Recorders
Cd drawer will not open
Sometimes the cause is a belt that has either broken or come off. If you need a new one just measure the diameter of the old one in MM. The put that into Google with the words "drive belt" and find the one close to your stated size.
Feb 21, 2013 | Crosley CR248 Turntable
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Sony casette recorder model cfd-8 drivebelts- require a pair of new drive belts, old belts streched hence new ones required
They don't appear to list the belts as a part.
http://www.encompassparts.com/models/?SONCFD8
If you can take them out and measure the overall diameter and cross section (square, round etc & size) I'll see what I can find.
Apr 19, 2011 | Sony Audio Players & Recorders
Where can i find the little rubber belt that connect the motor to the drive gear that opens the CD drawer in my CD player
Depends on which Yamaha CD player you have. But this part fits many models http://www.partstore.com/Part/Yamaha+Electronics+Corporation/Yamaha/CDC655/Yamaha+Electronics+Corporation/Yamaha/VQ776900/New.aspx If you remove the old one and measure it (diameter, width of belt and cross section type e.g. square, flat or round) you can get generic replacements from any decent electronics store for about £1 in the UK. Don't forget to allow for the fact the old belt will have stretched so you'll need a slightly smaller diameter replacement. See here http://www.studiosoundelectronics.com/beltmeas.htm
Feb 04, 2011 | Yamaha Audio Players & Recorders
Need the elastic band that helps run the tape deck. using a bog standard band from work but not sure how long this will last. any ideas regards spares???
Have you kept the old belt? If so measure the diameter and then look around the net for "Belt ??mm". If not measure the diameter of the one you have in.
Belts are standed and are not specfic to any machine.
Feb 17, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Looking for part number: Drive belt or kit for Fisher Cassette Model CR-124
good luck finding a part number for something this old. I might just measure the size (diameter) and width of the belt, and see if I couldn't get a generic replacement.
Jan 05, 2010 | Audio Players & Recorders
MY 2003 CHEVY S10 DISCHARGES WHEN IT GOES OVER 2000 RPM. ALTERNATER IS OK, I REPLACED BATTERY AND DRIVE BELT. NO CHANGE.
Check your belt tensioner to be sure the new belt is being held firmly on the pully. Make sure the pully on the alt is the correct diameter as the wrong size will effect the rate of charge.....Also make sure all your ground connections are clean and tight as this too can effect your electrical system.
Jan 01, 2010 | 2003 Chevrolet S-10
Need new belts for Grundig Tape Recorder TK5 1957
Hi there
regards Graeme
Jul 08, 2009 | Audio Players & Recorders
How big is a alternator belt for a ford festiva?
You can take the old belt into any auto parts store and they can measure it for you on a special tool that they have that measures the inside diameter of the belt. The belt is about a size 28, but you should just ask the auto parts store to give you the correct belt for you exact make and model of car.
Jul 08, 2009 | 1989 Ford Festiva
42 people viewed this question
 Grubhead
Grubhead
