Question about Canon PowerShot S1 IS Digital Camera
When I turn the camera on, the canon logo appears on the display and the red light in back above the menu button keeps blinking, but nothing happens. When I turn it on in the "taking pictures" mode or "view pictures" mode, it just hangs and acts like it has trouble reading the CF card. I've tried multiple cards and had the same problem, so I think it's the camera and not the cards. Any ideas?
Canon logo is starting of camara indications just as company manuals
Posted on Jun 15, 2009
How to enter service mode in canon ipf605
Ansewer
Enter the Service mode following the procedure below.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Information] button.
* Keep pressing the above buttons until "Initializing" appears on the display.
3) "S" is displayed in the upper right corner of the display showing the version.
4) After display of "Online", pressing the [Menu] button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
Aug 05, 2014 | Canon imagePROGRAF IPF605 InkJet Plotter...
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Red light blinks but nothing happens
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 02, 2009 | Olympus FE-310 Digital Camera
It won't turn on! I charge it, and the camera is no more than a year old, and yet it wont turn on. However, when it's on it's base, it can connect to my computer and turn on fine! Is it the battery?! Why...
Mine won't turn on...unless I hit the red button, then the menu button, then repeat...the red, then the menu. When the menu comes up, it wants to reset the date/time etc. I just ignore that and hit the menu button once more and it's ready to shoot. Pain in the you know what.
No more Casio cameras.
Jun 26, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Red flash and appears to be frozen
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
Jan 06, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Digital Camera Malfunction
mine just started doing the same thing a few weeks ago. I had downloaded pixes to the computer, went outside to take picture and it started acting up. strange lines appear on the screen, but the codes are all there, and you can view the pictures that are on the card. no, the card is not full, the batteries are fine. I think it has a virus built in to start trouble so we will go buy a new one!
May 27, 2007 | Canon PowerShot A70 Digital Camera
Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS HOPE THIS HELPS.
EBEN
Dec 06, 2006 | Panasonic NV-DS29B Mini DV Digital...
Panasonic PV-DV53D
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
Oct 16, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Canon PowerShot S1 IS Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
