Question about Hasbro Alphie The Learning Toy Robot
Reset Does nit register card
Reset casio se300s
Is it working with a card? Can you erase the memory of past operations?
Jul 06, 2015 | Casio Parts Cash Register PC Desktop
How can i get confirmation code for microsoft office professional 2007 full version?
I am nor sure as to a confirmation code you would be referring to. If it is to register the software, you should have the Key Code on the package or inside on a card. If the code is missing, you can order a new one online from the Microsoft website.
I do hope this answers your questions. If not, please repost with more details of the exact issue you are having.
Good luck.
N.I.T.
Jun 07, 2014 | Microsoft Office Professional 2007 Full...
If i program register at home can i unplug it take to store replug it will everything i program be saved?
Yes, you should be able to program the register anywhere. It will keep the information in memory stored on the register.
Good Luck.
N.I.T.
Jun 26, 2013 | Computers & Internet
My Nokia N9 cannot register the sim card. How can I solve this?
stop by your carrier they fix that stuff for you
May 22, 2012 | Cell Phones
Hi, I have a few Casio TE-4500F cash registers, and I am trying to copy the programming from one of the registers to the others using a CF card. I seem to have managed to format the card and save the data...
Oh dear. Why are you wiping the IPL? You are seriously screwing up the firmware in the machine. It might be best to see a dealer to have them change IPLs for you
Aug 17, 2011 | Casio Parts Cash Register PC Desktop
Can't get into my screen its locked
Maserati claims if you remove power from the radio by unplugging it or removing the fuse and then power it back up and do not enter a 4 digit code before turning the key back off than the system will be locked out for good.
I do not know how true this is though. Try removing the fuse again. See if the screen comes up were it will allow you to enter the code and try to see if it will let you enter it. Hopefully it works because that is a 7k radio (nit). You can also try removing the battery terminals to reset the car, but I would recommend the dealer do that because these cars are very finicky.
If the NIT screen says wait 20 minutes all the time no matter what, then you need a new NIT module, under warranty of course. Jeremy is absolutely correct in that if the NIT is in security mode waiting for a code and power is interrupted or voltage is too low, it will PERMANATELY lock.
Mar 06, 2011 | 2005 Maserati Quattroporte
One touch white balance
i have the e-500 and can only register one at a time. once you set the white balance using the one touch button, it stays that way until you one touch again or custom reset. however it may be possible to save to 'my mode' 1 or 2 ... or even 'custom reset' 1 or 2. according to the manual on page 119, it saves your wb setting and most of the other changes you have made.
reset camera... soft reset. Mode Dial to P, press Menu, right arrow (AF button), to card setup, down to custom reset, right to custom reset, OK, up to YES, the OK
Sep 24, 2008 | Cameras
LG Shine photo tranfer to sd card
ok, go to the picture, click options, then click either copy or transfer or send, the nit shoudl say from pone memory to sd card or vis versa
Jul 15, 2008 | Lands Phones
Hasbro Alphie The Learning Toy Robot Logo
78 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
