Question about Waterway Pool & Spa
Change light fixture
How do you hold nut and light?
Change fog lamp
Most of these are accessed from behind the face panel. There is going to be two nuts holding the fixture on. Make sure you unplug the lamp first. Remove the nuts and you should see from there how it all comes apart.
Dec 12, 2015 | Cars & Trucks
How do I open the fixture box on a fluorescent light
if its an old 2/4 or 8 foot tube light , these used the shade as part of the housing this is where the ballast /starter is located and other wiring is there too , to remove these old type , remove bulbs by gently twisting 1/4 turn and allowing tube ends to drop free(hold on to bulb !!) remove all bulbs this way , then locate the end where you'll see a nut , there's only one on one end , sometimes on fancy decorator lights they make the nut seem as part of the ornation of shade, but a carefull look and you will see the seams that make it removable , unscrew this and shade end will drop away , the trailing end will unhook when shade is aprox 33 degrees angle away from light these old fixtures can be quite heavy so be prepared for weight ! make sure you disconnect any power to light before working on anything inside of it ,including tube ends ,as I find these are whats bad most times (cracks)
Aug 09, 2015 | Home
How do i reattach the fixture on the liftgate of my 2007 Chevy Tahoe
try removing the trim from inside the boot and tighten the nuts up on the bolts that hold that section
Mar 21, 2015 | Miscellaneous
How can I change rear turn signal light in my 2004 ford expedition?
Open the tailgate, open the panel behind the light and you will see the light bulb sockets. There is also the nuts to remove the entire fixture. I got one at Pull-A-Part for ten dollars. The whole fixture brand new is expensive
Feb 09, 2014 | 2004 Ford Expedition
Replacing a light fixture
This is much simpler than it sounds, but if you're a total novice you'll need to read it all.
First, make sure power to fixture is off. Best method is to locate circuit breaker or fuse that controls that fixture's power. At minimum shut off the wall switch to it if there is one.
Next, remove the old fixture. Usually there are two screws or decorative nuts holding the base cover (canopy) on. On ceiling pendant fixtures there may be a retaining ring holding up the canopy, unscrew this ring counterclockwise and the canopy will drop over the support chain, exposing the junction box where the wires are connected.
It is critical at this point that the power is off.
Modern house wiring and fixtures are connected with three wires.
Green or bare copper = ground (earth)
White or grey = neutral
Black, Red, Blue or any other solid color other than green, white or grey = power or hot wire (this is the wire that is controlled by a switch.
For simplicity I will call the three: Green, White and Black.
The next step requires you to carefully pull the wires out of the junction box and isolate the black, white and green wire connections from each other. Make sure the connectors (wire nuts) for each connection are accessible.
Warning: With old or over heated wiring, take extra care not to crack or disturb the insulation(wire covering) on any of the wires. If insulation is crumbling away exposing bare wire, stop and call an electrician! Do not turn the power back on until he has repaired those damaged wires, they could start a fire.
Isolate the connection between the black house wire and black fixture wire. Remove this wire nut. At this point I usually use an electrical tester to double check that the power is off by touching one side to the newly exposed black connection and any grounded metal part nearby.
(Note: some multiple switched (three way) circuits may use a white wire as a power wire. If the black fixture wire is connected to a white house wire, mark that white house wire with black electrical tape for future identification.)
Once you are positive there is no power at the fixture junction box remove the connectors from the white and green wires.
Detach the old fixture and it's mounting bracket.
Re-attach the new fixture using bracket and new connectors that are usually provided. Some brackets have a green ground screw. Wrap the bare ground wire clockwise around that screw and tighten it down leaving enough remaining ground wire to attach to the fixture ground.
If the wires to the new fixtures do not have a 1/2 inch of exposed bare wire at the ends (stripped) you must do so. I use a wire stripping tool but you can do it with a sharp knife being careful not to nick the metal wire.
Once the wire tips are stripped, hold the tips of each color pair together side by side, slip the wire nut over them and twist clockwise until snug. (White to white, black to black etc.)
Take care that the new wire nuts are secure at each connection. Do not over tighten them but insure that they are correctly attached by gently tugging on each wire. When completed the black and white connections should have no exposed bare wire showing.
The Green (bare copper) wire is there for safety and never carries current, hence exposed wire is not an issue on ground wires.
Assemble and attach the new fixture according to instructions in the box.
Pendant ceiling fixtures usually require additional assembly steps including adjusting chain height, looping wires through the chain and slipping retaining nut and canopy over chain prior to connecting. Always follow directions that come with the fixtures.
When in doubt, call a professional. Electricity is dangerous.
Apr 06, 2013 | Dryers
New fixture installation
Fixture is not identified.
Usually each light fixture is held in place with 2 screws -or- a center nut.
Remove old light and you can see 2 wire nuts covering black wire and white wire, and possibly another wire nut covering green wire or bare copper.
Untwist wire nuts.
Attach new light fixture wires same way as old was removed.
Make sure black wire goes to black wire on light. White to white, green to bare copper.
Copy and paste following links to see basic wire nut, and single-pole and 3-way switch wiring:
http://waterheatertimer.org/How-to-select-right-wire-nut.html
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
Jun 05, 2012 | Home
Tail light bulb replacement on 2010 dodge challenger
there should be a fixture in the boot/trunk that holds the lights,that clips into a panel, find the clips that hold it in and release the lights fixture then you can change the bulb, clip fixture back in
Oct 08, 2011 | 2010 Dodge Challenger
How to change the headlight
Open the hood and look on the back of the headlight fixture for a large plastic nut... This is the retaining ring that holds your headlight bulb in the fixture.
If by ' problem with my headlight shining' you mean your headlight no longer works , you can use the above to replace the bulb and that should solve the issue.
HOWEVER , if by ' problem with my headlight shining' you mean that the light is not aimed properly , you will need different instruction on how to solve the problem.
Jul 15, 2010 | 2004 Mazda 6
Changing the tail light bulbs on a 2000 mazda 626
The Tail Lights Are Accessed From The Inside Of The Trunk There Will Either Be A Panel Immediately Behind Where The Light Is Or Carpet. Remove It And It Will Give You Access To The Rear Of The Bolts Just Grab Twist And Pull And The Light Will Come Out.
Jan 26, 2009 | 2000 Mazda 626
How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Dec 29, 2007 | Dryers
Pool & Spa Logo
20 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
