Question about Vehicle Parts & Accessories
Changing a bearing for car and it split is that ok?
99 nissan sentra bearing replacement
  • 3 Answers
Depends on the crank. or do you mean wheel bearing?
Posted on Sep 14, 2014
Nissan sentra 2.5 every time i try to pass a car the engine reves but it goes no were
Is it a manual or automatic trans, and are you saying the clutch or trans is slipping ?
Jan 23, 2013 | 2003 Nissan Sentra
99 nissan sentra exhaust
It is best to weld this back in place, sometimes you'll nedd an extra piece of pipe to correct this problem
Jun 15, 2010 | 2002 Nissan Sentra
Change rear bearing on a 2001 Nissan Sentra
Most newer cars have a bearing that is pressed in to the hub. In order to do the repair you should have to replace the entire hub. This is actually easier and cleaner because the bearings are lubed, sealed and pressed in the hub. They usually cost around $30 and should be available through your local parts store. In most cases the hub is held on by a large nut so I recommend that you make sure you have a socket that is large enough.
May 13, 2010 | 2001 Nissan Sentra
My nissan sentra fe 99 model has a slow reaction whenever i accelerate my gasoline
try doing a fuel system cleaning service. most oil change places will do it for about 60 bucks or so, also have the fuel filter changed, may help a bit
Sep 27, 2009 | 1999 Nissan Sentra
How do you change rear wheel bearing on a 2004 nissan sentra
Yes it is as easy as it looks. If you had the tire off and figured out that it looks easy, you shouldn't have much problem.
Mar 21, 2009 | 2002 Nissan Sentra
How to replace front wheel bearings in 2006 nissan sentra
hi..check on the following link to replace the
wheel bearings.
http://autorepair.about.com/od/fixityourself/ss/wh_bearing_old.htm
check it out..
thank u..
rate me..
Mar 06, 2009 | 2006 Nissan Sentra
Gas smell
check for leaks in the fuel line from the gas tank up to the engine bay.the humming sound you hear at the back is your wheel bearing.it needs to be replaced.
Aug 10, 2008 | 1999 Nissan Sentra
Nissan sentra gxe 03 rear wheel hub bearing problem
Easy job ! just rem to get a gear puller for the antilock gear and install same as came off old one Parts around 100$ each apx 1/2 hr each side
Jun 12, 2008 | 2003 Nissan Sentra
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
