Question about GE Profile JT912 Electric Single Oven
COOLING FAN DOES NOT STOP AFTER HOURS
I turn off the built in oven after cooking ends. Cooling fan starts working. Hours pass but it still cools. I can hear the sound coming. After 4 hours it still was trying to cool down. Can anyone suggest me what the problem is?
  • 431 Answers
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Posted on Jun 15, 2009
Trying to cook prime rib that needs to rest in hot oven for 2 hours. How do I turn off cooling fan
that fan is a cooling fan but not for the food,it's to cool down the electronics in the oven like the clock assy. so it's doing it's job,that's why i tell people not to use the self clean feature on stoves or ovens,the temp. gets up to 1000 degrees and it will sooner or later damage the electronics in the machine,so if you're gonna use it use it after the holidays,i see people use it the day before thanksgiving,the oven stops working and parts have to be ordered or if it's an older oven you can't get parts anymore and they can't cook so that fan is a good thing.happy holidays.you have to set the oven on a low setting just to keep the oven warm.like 200 or 225,also some ovens have a warming draw under the oven door,if you have this make sure you clean it first,i've seen them filled with dust because nobody ever uses it.here i googled this for you
https://www.chowhound.com/post/meat-warm-360832
Dec 23, 2017 | Ovens
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
Why does the cooling fan on the oven continue to run?
Never heard of a cooling fan in an oven.they are usually used for fan baking, which speeds up cooking.
Sep 19, 2014 | Ovens
Why fan stays on for hours after turning oven off
There is a thermostat inside that controls the cooling fan. It will keep it on until it is cool, it is a safety feature.
Aug 12, 2014 | Ovens
Electrolux Gas Oven EOG6330; Cooling fan still on several hours after oven turned off. Solution, please.
hi the change over stat is probably faulty one of the wires from the cooling fan will go directly to it. there are 3 wires on it. just replace it. 311 23 97-00/9 is the part no approx £18 +vat
Feb 09, 2011 | Electrolux EOG6330 Gas Single Oven
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JT912 Electric Single Oven Logo
549 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
