Question about Banks Power Pack System 49481 Ford 6.8L Motorhome A 1997-03
E450 6.8l will not accelerate
Idles rough, timing varies
Bank 1 and 2 rich, rough idle. Have replaced upper and lower intake gaskets, TB gasket, MAF sensor, throttle position sensor, EGR valve, all 4 o2 sensors, both cats, all 8 fuel injectors, fuel pressure...
I'm going to assume the temp sensor is reading normal ?
And there is no restriction in the return line to the tank ?
Any chance there is excessive fuel in the oil ?
Aug 27, 2013 | 1997 Chevrolet K1500
Rough idle/ not accelerating/coolant leak
Rough Running Engine - James on Engines #2 - Bell Performance
https://www.bellperformance.com/blog/rough-running-engine
Apr 21, 2015 - When diagnosing an engine with a rough idle, there are certain things that must be ... If the problem does not reoccur, the codes will be erased by the computer. ... when accelerating the vehicle, which causes a higher fuel demand. .... it was water in gas...added added Gas LineAntifreeze/Water Remover.
Mar 17, 2017 | 2000 Ford Focus
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
My 2000 bonneville idles rough. 3.8 liter. it even
Mine did this at one time, and it was only a bad plug wire. Give it a tune up and see if it works. 170k miles is awesome, I have 145k now and it runs great, but had to have ac replaced this week :( Good Luck!!
Feb 26, 2010 | 2000 Pontiac Bonneville
I have 2002 audit quattro TT with 180k miles. When I do a normal acceleration the car surges and rpm drop but pick back up. If I accel hard it runs fine. Also at idle at times it varies 200 rpm like a
this sounds similar to a problem i had. as the rpm went over 2000 the engine would stop for a split second and then kick back in.
after a few days looking my garage finally found the problem was a faulty air mass meter.
this cost me £200 in total to be repaired.
May 06, 2009 | 2002 Audi TT
Rough idle and missing during acceleration
you could have clogged fuel injectors or fuel filter.
Apr 27, 2009 | 2001 Mazda Tribute
1996 FORD CONTOUR 4CYL ROUGH IDLE ROUGH ACCELERATION
no problem. If you are getting that low of voltage on a load then you might want to test the alternator as well to make sure it is running at capacity.
Feb 23, 2009 | 1998 Ford Contour
Rough idle / varying oil pressure when accelerating
Ok not to keen on newer vehicles actually prefer the carburated ones, but oil pressure is supposed increase on your gauge when accelerating. If it wasn't going up before and just staying at 40 the needle might have been stuck. But idle should be 40 lbs and when you work the moter (reving or driving down the road) the guage should show an increase for every 1000 rpm above idle. Second if you can get a hand held scanner (bought mine off ebay for $30) check for any codes in your computer you will probably find that you either have a bank running wrong or some other sensor that needs to be changed. I'd go with getting my own scanner it saves alot of money and time, garages make their money here.
Jan 03, 2009 | 2005 GMC Yukon
Idle varies way too much
try replacing your map sensor or your throttle position sensor.
Nov 23, 2008 | 1990 Honda Civic
1997 Integra Idles Rough
Does the car accelerate normally under heavy acceleration, or does it feel a bit lethargic?
Fuel economy?
Check engine lights?
Engine shaking at idle or other speeds?
Everything work on it (engine wise)?
Jul 08, 2008 | 1997 Acura Integra Type R
Banks Power Pack System 49481 Ford 6.8L Motorhome A 1997-03 Logo
76 people viewed this question
Top Banks Power Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Banks Power Craft and Hobby Expert? Answer questions, earn points and help others
