Question about Electronics - Others
Maxtor One Touch 4 Mini not getting detected
I have a Maxtor One Touch 4 Mini 120 GB. It was working fine for a few days I took a backup of my hard drive which I was supposed to format. Just to ensure that the things have been copied safely I connected it to another PC W/Vista but it wont get detected, tried on W/XP prof., W/XP Home but still the same, though the device manager USB and the Disc shows its presence, but it is not getting displayed in Windows explorer. What possibly could be causing this absurd behaviour?, well anyone wirth a solution is most welcome.
I am trying to load fresh drivers, will revert if it works out.
Dr_Joseph
  • 86 Answers
SOURCE: Please insert a disk into Drive E
probably you removed the pen without properly stopping the device.
usb pens are sensitive about this. you must use an icon that is on traybar to stop usb storage devices before removing them.
now it is probably in read only mode or damaged.
if it is still inside warranty try to replace it.
Posted on Jan 26, 2009
SOURCE: maxtor onetouch 4 mini usb 2
You cannot download drivers/software for the Maxtor Mini at the above URL. When you select the Maxtor Mini, you're redirected to a contact form you have to fill out just to get the software. Pretty lame on Seagate's part! I'll think twice before purchasing anything else from them.
Posted on Aug 28, 2008
WeListen2You
  • 538 Answers
SOURCE: Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Posted on Oct 20, 2008
ashishd19
  • 35 Answers
SOURCE: Unable to access my 4 GB Transcend pen drive with Windows Vista
Here are the 3 possible solutions to this problem,
SOLUTION 1 :-
Make sure the you have the Service Pack 1 installed for you vista computer.
You can find it out by opening the run command and type "winver" (without quotes) there. If it's not showing SP1 please update Windows Vista to Service Pack 1 which includes the update to fix this problem as this was the problem when vista was launched but fixed with SP1.
If updating vista does not resolve the issue try the solution provided below:
SOLUTION 2 :-
Manually locate the driver within the Vista operating system.
Microsoft Windows Vista may not find any driver for the device that is plugged in the USB port because the usbstor.inf (for MSC device) or wpdmtp.inf (for MTP enabled devices) is not present inside the C:\Windows\INF folder.
To resolve this issue, you must copy the driver files to the C:\Windows\INF folder.
Browse to the following folder:
1. C:\Windows\System32\DriverStore\FileRepository.
2. Look for the folder that starts with usbstor.inf_.
3. Copy all the files inside this folder to C:\Windows\INF.
4. Disconnect and reconnect the device.
If the problem still persists, try this Solution:
SOLUTION 3 :-
Clear hidden devices and make changes to the Registry
First backup your registry by  following these steps,
1. Click Start
2. Type regedit on the start search field, then press Enter.
3. Click File then select Export.
4. Under Export Range select All.
5. Type in the desired name to be saved.
STEP 2 - Remove Hidden Devices
1. Click Start..
2. Type cmd on the start search field , then press Enter.
2. Type set DEVMGR_SHOW_DETAILS=1 and press Enter.
3. Type set DEVMGR_SHOW_NONPRESENT_DEVICES=1 and press Enter.
4. Type start devmgmt.msc and press Enter.
5. Device Manager window will appear
5. Click View, then select Show hidden devices.
6. Click + to expand Imaging devices, Unknown devices, and USB devices.
7. Verify if there are any devices and unknown devices (including grayed out devices). Uninstall.
STEP 3 - Remove all oem*.inf files
1. Click Start.
2. Type cmd on the start search field and press Enter.
3. In the command line, type in the following commands and press Enter after each command:
  cd \windows\inf
  ren infcache.1 *.old
  ren oem*.inf *.old
  del C:\windows\setupapi.log
  exit
STEP 4 - Remove entries under HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB
Remember,if you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start
3. Click on the "+" symbol beside HKEY_LOCAL_MACHINE
4. Navigate to \System\CurrentControlSet\Enum\USB.
5. Highlight and delete all the VID_xxxx entries.
Please note that if you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
After this turn off your PC completely then with the PC turned off, plug the USB flash drive to a USB port and then turn on the PC.
Now, a New Hardware Detected balloon will appear and the USB drivers will load automatically.
Please let me know if the problem persists.
Posted on Nov 19, 2008
SOURCE: XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Posted on Nov 21, 2008
Cannot detect my Maxtor One Touch III harddisc
http://www.fixya.com/support/r4247716-usb_device
Your first stop is there to see ALL the fixes for common portable hard drive issues
Aug 20, 2010 | Maxtor OneTouch III Mini Edition 120GB...
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
How do i find a usb adapter for my maxtor one touch 4 mini 120gb it broke?
You can buy a USB to USB mini cable at almost any store with PC accessories, even Walmart. Buy a high quality one since the drive is powered from the USB 2.0 port. Good Luck
Jul 23, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
BACKUP
i think if you just start the maxtor manager and clik on back up, you should be able to select which files or drive you want to back up . hope that helps
Sep 23, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Backup error
It's been suggested that the software Maxtor bundles with the drive is unreliable at best. you could uninstall the software from your computer then reinstall the latest version to see if that resolves your issue. Otherwise you will be forced to use ntbackup or a 3rd party backup solution.
Jun 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Your solution
detection issues with the maxtor. Although the original one is for Maxtor one touch IV, the solution there should work with the III also..
May 12, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor mini iii 120 gb HD
Uninstall the back up software, and choose another or reinstall it.
Oct 17, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Electronics - Others Logo
608 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
