Question about Intel Desktop Board D845WN Motherboard
Intel desktop board D845wN - no screen display
Hdd,cd/dvd spinning , cpu fan working, but no screen display tested the AGV adapter its working
  • 255 Answers
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Posted on Jun 15, 2009
Intel desktop board d845wn front panel powder led, power switch, hdd led, reset switch connection problem.
Hi, here you can read info and download drivers
for your mainboard:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845wn
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
Sep 20, 2011 | Intel Desktop Board D845WN Motherboard
After installing my Intel D845WN m/board and connecting up the power supply with the ram, AGP card etc., the processor fan on top of the heat sink started running when I switched on the main power supply...
You probably have the case panel connections in the wrong places. Double check the board's manual and the connectors. Most case manufacturers have the connectors printed with their functions.
Oct 14, 2009 | Intel Desktop Board D845WN Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
133hz sdram problem
Please check this Intel link that shows specifications for memory that can be used in the Intel D845WN motherboard.
http://www.intel.com/support/motherboards/desktop/d845wn/sb/cs-008941.htm#1
When upgrading or increasing memory. The DIMM's should be the same. The Intel D845WN board requires the memory to run at 3.3volt. If the memory you are adding is within the Intel spec's, than switch the two Dimm's. Insert only the new DIMM & check if the system hangs. If it does than it is possible the new memory it either not compatable or is defective. For more information about the D845WN board download the manual for you're Intel board. http://support.intel.com/support/motherboards/desktop/d845wn/sb/cs-008937.htm
Luck!
Mike
May 19, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Won't boot, display stuck at Intel desktop board, can't go to BIOS
I had this exact same problem, turns out i just needed to unplug a couple USB devices that were conflicting with the startup. It worked inexplicably well. If you have an external HD i'd start by unplugging that, then other accessories.
Dec 31, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Intel Mother Board D845WN
Seems there is a loose wire, loose card, motherboard failure or mis-plugged wire. IS everything in right?
Nov 09, 2007 | Intel Desktop Board D845WN Motherboard
No screen display at all and no short beep for post-intel D845WN board
Try the old memory back in and see if you get the bios screen showing up, if not find the clear cmos jumper either marked JBat 1, clrclk, clrcmos or similar and try again. If neither your old memory or new no longer allows the pc to boot, i would say that the motherboard has been stressed when you have fitted the memory by forcing a flexing in the board and damaging the cmos chip, only replacing the board can resolve the issue if that is the case
Jul 03, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Intel Desktop Board D845WN Motherboard Logo
254 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
