Question about Axion AXN-8701 7 in. Portable TV
How to replace battery , open case, get access to battery compartment
How to open battery compartment
Battery compartment latch broken
battery latches broken, battery needs replacement, you will end up forcibly removing the battery thereby doing more damage to battery latches but avoid main computer case. cannot open computer to find solution around broken latches for there are screws that needs to be removed under battery.
Sep 06, 2013 | Dell Computers & Internet
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    I have a Sears Craftsman garage door opener with a Smart 3-Function remote control. I need to replace the battery, but cannot see how the case opens to give access, and no longer have the owner's...
    Depending on how old your Remote Control Smart 3 Function remote is determines on how to access the battery compartment. It will either have a small screw which needs to be loosened or if it doesn't have that, it will pop open when a very small, thin, flat blade screw driver is inserted in the side seam of the plastic housing. It's going to be tight, so be gentle with it. Once you access the wafer battery, note which side is up (+ or -). That's the way you want to install the new battery.
    Hope this helps you out.
    Feb 14, 2011 | Sears Craftsman Remote Control Smart...
    Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Replacing batteries on Energizer Hard Case Lantern
    If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
    Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
    Removing acer motherboard to reset password
    You don' t have to remove the motherboard. Remove the CMOS battery. The CMOS battery on a laptop is many times accessible from under the computer when you take the battery out. I've found them just outside of the main battery compartment up under the palm rest. Acer may be different. If you can't find it by looking up through the holes opened up by removing the access covers in the bottom of the case, you just may have to split the case to get at them. Just be careful when you do it. All cases come apart, but many require the removal of a number of screws first.
    Try removing the battery for about a minute first (with the system unplugged, of course.
    Sep 09, 2009 | Acer Aspire 3680 Laptop
    I have a 6" mitutoyo digimatic code # 500-130 and would like to know how to open the battery compartment to replace the battery?
    There should be a battery cover on the back of the case that will have a small release catch on it that will open the compartment up. Mine has 2 batteries in it. Hope this helps you.
    Sep 01, 2009 | Mitutoyo 505 677: Test & Measurement...
    How to open remote control Sony RM-Y181
    There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
    I assume that's what you mean by open?
    :D
    Aug 10, 2009 | Televison & Video
    I can't find the compartment to replace battery on 220 logitech
    The battery cover release is located on the bottom of the mouse near the end. Push the button and the top will pop off so you can have access to the battery. When finished replaceing the battery just push the cover back on.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Aug 03, 2009 | Logitech V220 Mouse
    Need to open handset for kx-tc1025 cordless phone. has 2 screws in battery compartment
    After taking out the two screws from below the battery compartment, the case will separate slightly on the bottom. Take a screwdriver and carfully pry the case open along both sides, working from the bottom toward the top of the handset. This will free the back of the handset from the primary components. It will simply snap back together when done and then replace the two screws.
    Apr 05, 2008 | Panasonic Lands Phones
    Axion AXN-8701 7 in. Portable TV Logo
    93 people viewed this question
    Top Axion Televison & Video Experts
    Steve
    NOEL
    NOEL
    richie46
    Are you an Axion Televison and Video Expert? Answer questions, earn points and help others
