Question about Sony Ericsson Xperia Neo
Connection phone for bluetooth to car
Require instructions for connection bluetooth to car
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Instructions:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
ALL OF A SUDDEN MY BLUETOOTH CONNECTION FROM ALCATEL A392G AND MY CAR WHY?
Refer to owners manual of vehicle Dashboard Interface or DIN instructions. Dealer or mechanic can reset factory memory. Correcting connections with wireless sometimes requires unpairing and repairing wireless devices without the engine on, in the case of electronic interference.
Apr 07, 2014 | Alcatel Cell Phones
Want to connect to hotspot off phone
You can connect via wireless, bluetooth, or USB following on screen instruction on phone but the Hotspot feature requires a fee near $30.00 to subscribe.
Mar 27, 2013 | Gateway DX4200-09 PC Desktop
I want to connect my phone to my pc by bluetooth what do i do ?
Dear user,
If you have a desktop you need a Bluetooth dongle and required software installed in your PC, if you are using a laptop with Bluetooth then its good, all you need to do is switch bluetooth ON on both devices (keep them in visible mode)
send the required file from target device to destination device , accept all notifications as yes on both
if you want to use it for surfing on PC by making ur mobile as modem then install the motorola software from CD. and follow the instructions to connect Bluetooth.
May 04, 2011 | Motorola Mobility Defy Cell Phone
What is the passcode for vh300 bluetooth sony ericsson?
Accessory instructions: VH300 Before you can use your Bluetooth
Aug 18, 2010 | Sony Ericsson VH300 Bluetooth Mono...
Jaguar x type bluetooth
If your car has the Bluetooth phone option fitted (most models with the touch screen 2006 onwards do) You may get the message SIG instead of Phone connected.
Please see http://www.blujag.co.uk for detailed bluetooth instructions.
Jul 16, 2010 | 2005 Jaguar X-Type
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
Bluetooth instructions
This needs to be done differently depending on the type of car you are using. Some cars require you to search for the cars bluetooth system from the phone. Others have the car search for the phone. most will have a password that needs to be eneterd on the phone to sync them together once they have been discovered.
Feb 21, 2010 | Cell Phones
I lost the instructions that contain the unlock code to enable bluetooth access... I got one of those bluetooth adapters for my computer and i'm trying to pair my computer with my mobile phone. My phone is...
If you want to pair the phone with the PC through BT then all you have to do is to give and number like 00 or 0000 as the code. on the phone and press enter. Then the PC will ask for the code. You should give the same number there too, ie, 00 or 0000, whatever you gave earlier. Then the phone will connect to the PC through BT.No instruction manual is required for this. Once your phone and PC are paired you can set then to connect with out this code being given every time.
Dec 04, 2009 | Computers & Internet
Connect to the internet via
Once the Socketcom Bluetooth card is inserted in the Toshiba Pocket e570 PC and the software has been loaded, the following instructions will set up the Toshiba PDA & Ericsson T39 mobile phone to connect to the Internet. Click on the Bluetooth icon in the bottom right hand corner. Click on Get Connected! Select the device under My Bluetooth phone is: In this case the Ericsson T39. The following information gives details on how to change the name of the Mobile device. Once this has been read, click on Next. The phone now has to be made discoverable so that the PDA will detect it. To do this, use the down arrow on the phone to select Extras and then click on Yes. Scroll down to Bluetooth and Click on Yes. Select Make Discoverable and a message on the phone will appear saying that the phone is discoverable for the next 3 minutes. Click on Next on the PDA. The PDA will now look for a Bluetooth device(s). Once the mobile is detected the PDA will search for the Device Name of the mobile. Click on Select and the devices will not connect and create a partnership. The following Device Bonding window should appear to create a bond between the PDA and phone. Click on Next. To create the bond a passkey must be entered on the PDA. This may be a between a 4-16 digit code. N.B. We would advise that the code be kept to a numeric sequence as the keys contain more than one letter on them, i.e. for the letter L, the number 5 key will need to be depressed 3 times. Once the passkey is entered, click on the Reply button. On the mobile, click on Yes to accept the incoming pass and then enter the same passkey. Click on Yes again to confirm. If the two values are correct, a message will appear on the phone telling you that the devices are bonded. The PDA should now congratulate you on your connection. For Internet access via Bluetooth, please follow the steps outlined below. The above instructions only need to be carried out each time a connection is required. However, the instructions below only need to be setup once. Click on Start, then Settings from the drop down menu. Click on the Connections tab at the bottom of the screen followed by the Connections icon utility. In the first drop box labelled "When needed automatically connect to The Internet using these settings" select New. Under the General tab you will be prompted to give the new connection a name, e.g. Bluetooth. Select the modem "Bluetooth Phone" and click on Next Make sure that the fields for the boxes titled Country code and Area code, are empty. The next field requires the full telephone number, including STD code, you wish to dial, i.e. your ISP telephone number. Put this in and click on Next. The next page contains a time out clause if the PDA is unable to connect within a set time. By default this should be 120 seconds. Make sure the tick box for "Wait befo
Sep 07, 2005 | Toshiba e570
Sony Ericsson Xperia Neo Logo
14 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
