Question about Haier HLH406BB 40 in. LCD HDTV
When it worms for 15-20 it shuts of
When it working it is good
    Top Expert:
  • Haier Master
  • 75,591 Answers
Main power supply regulator board [SMPS] fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 27, 2014
Door shuts but opens without touch button , just fitted new worm gear this is a chamberlain model41a2817
If the unit was working before replacement and you lowered opener power head and removed wiring ensure that the safety sensors are wired correctly.LIFTMASTER Garage Door Openers 41D3452 Limit Switch AssemblyPerhaps your limit switches may need to reset, (located close to gear assembly) also the closing force may need to be adjusted. Good luck
Aug 18, 2017 | Building Materials
Have the daytime running light problem wont shut off changed switch just pulled fuse 31@33 fuse box under hood they were very hot but not blown now what can of worms did i open now
You don't need DRL if it s not a required pass test. pull the fuses and relays. DRL is controlled by the BCM( body control module). Your can of worms can be costly..If your lights work, pull the fuses.
Aug 21, 2015 | Cars & Trucks
When I plug my worm light into my GBA it shuts off?
it sounds like the light is shorting out and thats why the GBA turns off to protect it's self
Dec 16, 2013 | Nyko Worm Light Advance for Game Boy...
Not getting oil to blade tried the screw to adjust but still no oil getting throu !!
Your worm gear assembly is probably frozen in with sawdust and dirt. Take off the oil gear assembly. You will need to take off the clutch and the sprocket, the worm gear is directly underneath. Sometimes they are made out of plastic, sometimes of bronze. They use plastic for newer saws. If the gears do not turn easily, when you use your finger to turn them when they are off. then it is probably a good idea to buy a worm gear and then totally clean the assembly. Put in the new gear and it should work. Also check your chain bar check that the hole is clean. They also have a seal around the worm gear under the clutch assembly. It is good that you replace that too.
Nov 23, 2013 | Garden
L500 blaster worm keeps shutting down my laptop, keeps bringing up a spyware program then shuts cant open task manager as it closes as soon as it opens cant open explorer either
Hi
You have a virus,worm,trojan,etc on your computer.
Keep tapping F8 to enter Safe Mode as the computer is starting.
Once you are in the Safe Mode then go to the following website and download,install and run the FREE Microsoft Safety Scanner.
It will remove the virus,trojan,worm,etc from your computer.
It may take quite a while to scan and repair your hard drive, it depends on the size of your hard drive.
Once the Microsoft Safety Scanner is completed running, it should have removed the virus,trojan,worm,etc. from you computer, but if it didn't remove the virus,trojan,worm,etc. from your computer then it will give you an option to connect (real time) with a Microsoft professional (FREE) and he will take over control of your computer (with you permission) and finish the removal process.
Please take time to rate me
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Aug 31, 2011 | Toshiba Satellite L500 Series Notebook
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Haier HLH406BB 40 in. LCD HDTV Logo
52 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
