Question about Aircon Mini Split Replacement Pc Board
Not turn on a/c
Using remote control a/c not turn on
How to get this remote control to turn the 2004 Sylvania TV on/off
There is a fault with the remote control and it is not worth trying to fix it and not worth replacing the stock remote control unit even if the manufacturer could still supply one for that TV.
The best option is to just buy a very basic generic remote control (quite inexpensive) from an electronics store which will work with many TVs and use that remote to turn the TV on and off. Use your stock remote for all other functions if it is still working well on those functions.
I had a friend with the exact same problem with her stock remote a while back. I purchased a simple generic remote control on special for around $20 which she now uses to turn the TV on and off. .
Nov 21, 2015 | Sylvania Televison & Video
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
on Jun 10, 2010 | Televison & Video
Tip
DirecTV Remote Control Code Search Tosearch for a control code for your TV...
Tosearch for a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Slide the MODE switch to the TV position.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by 1:
  5. Aim the remote at your TV and press the PWR key once.
  6. Point the remote at the TV or component and press
    CHAN ^. Repeatedly press CHAN ^ until the TV turns off.
  7. When the TV turns off, press and release the SELECT key.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
Remote controller
The remote control you uses need cleaning. Check this site to get more details about how to check and clean a remote control. Pull up older posts there. One among has details.
Mar 31, 2013 | Yamaha Remote Control RAV252 p/n:WE458500
How do you program a Dish Network Remote to control a DirecTV receiver?
  • 1 Turn on the electronic device for which you'll be using your remote control. You will have to do this manually by pressing the "On/Off" button on the device.
  • 2 Locate either the "Code Search" or "Setup" button on your remote control. Which one you have will depend on the remote control.
  • 3 Hold that button for anywhere between five and 10 seconds. The light on your remote should then turn on. Depending on your remote, the light will either blink or remain on after you release the button.
  • 4 Press the corresponding button on your remote for your device that you are programming. In other words, if you want to program your remote to your television, you would press the "TV" button.
  • 5 Use the numbers on your remote to enter the three- or four-digit code for that particular device. The codes for your remote control will be found in the manual. Don't worry if you have lost the manual. You can find codes for practically every remote control on the market on the Internet. Visit the website of the manufacturer of the electronic device (TV, DVD player, among others) or log onto the "Universal Remote Control Codes" website. Once you have entered the code using the remote, you should notice that the light on your remote has turned off.
  • 6 Point your remote towards the device and attempt to turn the device off. If you can do so, you have programmed your remote correctly.
Programming Without Remote Control Codes
  • 1 Repeat Steps 1 through 4 found in Section 1.
  • 2 Begin pressing the "Up" channel button found on your remote. You will probably have to do this a few hundred times (or anywhere between five and 10 minutes). Once the channel changes, your remote will be programmed. Turn the device on and off using your remote to finish programming.
  • 3 Use the "Power" button if the channel button did not program your remote control. Again, you will probably have to press the "Power" button a few hundred times. Once the device that you are programming your remote to has turned off, you will know that you have programmed the remote control correctly.
Sep 14, 2011 | Televison & Video
Tip
  1. Turn on the TV.
Track lighting remote control similar to that of ceiling fan?
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
Jun 03, 2010 | Universal Remote Control Hampton Bay...
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Rca remote with no code search button
You didn't mention the model of the remote so try http://www.fixya.com/support/t839679-rca_remote_no_code_search_button
and see if it is listed.
If this works please repost,
MM85
Jul 27, 2008 | RCA Universal Remote Control
Aircon Mini Split Replacement Pc Board Logo
12 people viewed this question
Top Aircon Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Aircon Heating and Cooling Expert? Answer questions, earn points and help others
