Question about Sears Kenmore Elite Electric Dryer 69278
Static shield button flashes until dryer starts dryer when the button had t been pressed
When normal is selected the static shield button flashes and the heat cannot be adjusted.
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
No output
You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Mar 25, 2014 | MGE UPS Galaxy 3000 UPS System
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
I have an HP Lasejet 1320 printer and I am trying to reset static IP Address as we are moving from one network to another. I need to know how I can determine the mac address of the printer as I can...
To find the static IP and Mac Address of your printer, press and hold green button for 10 seconds until green and yellow light starts blinking together, it will take out 3 print outs, 1 is printer information, 2nd will be configuration page, 3rd will be the toner status page,
Also you can Check your printer manual. This is the easiest and fastest way to find the printer's MAC address
Alternatively Print out a configuration page.
If you require more assistance, feel free to reply to this post
Thanks for Asking FixYA!
Regards, BA
Feb 08, 2011 | HP LaserJet 1320 Printer
Turn my acer aspire 3680 2022 on and get a screen that said we apologize for the inconvenience but windows did not start successfully. a recent hardware or solfware change might have caused this.then it...
It appears that the issue might be with some hardware malfunctions. It may happen due to hardware failure, BIOS mismatch or due to
static charge. Let us try the basic troubleshooting. Turn Off the
Computer, remove all the devices attached to the computer, the power
cable and battrey, now holdon the power button for 15 secs (make sure
adpater and battery are uplugged) it will drain out all the static
charge. Now, restart the computer and keep on tapping F2, you will enter
to BIOS setup utility, press F9 (click "Yes", if you are prompted) and
then press F10 (Click "Yes", if you are prompted), it will restart the
computer. If still it is not booting to normal mode, then we have to
perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer,
now as soon as you hit the power button, keep on holding "Alt" key &
keep on tapping "F10" key, i.e Alt+f10, it will open the recovery
console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
May 21, 2010 | Acer Aspire 3680 Laptop
My zanussi ZBS773 wont switch on, the clock is showing and the wrong time and the decimal points are flashing, not sure if this is something to do with the timer, but that is showing 0.00. Not sure what...
If numbers are flashing press button "-" or "+" .When the correct time is displayed confirm the setting by pressing the square button with a "c" on. The clock will start runnning.
If the numbers are static press buttons l-> and l-> in at the same time and hold both of them in until the numbers start flashing . Release buttons l-> and ->l
then adjust the time by pressing "-" or "+" and confirm by pressing the square button with a "c" on .
Apr 11, 2010 | Zanussi ZBS963X Electric Single Oven
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
How to set date and time on a sports cardinal watch
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
Static/White Noise
Scroll down to the speaker set option. activate it then push the > button. You will see the test below the speaker diagram.
Feb 08, 2007 | Zenith XBS344 System
Sears Kenmore Elite Electric Dryer 69278 Logo
14 people viewed this question
Top Sears Dryers Experts
Dan Webster
Dan Webster
Big Texx
Big Texx
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
