Question about New Balance 1400 Treadmill
Heart rate will not read heart rate. Sometimes stops the whole machine
My Skechers GOwalk Strapless Heart Rate Monitor (Basic; Model Number WR30M; Distributed by Sports Beat, Inc.) will not read the heart rate. I bought this digital watch new, and it worked in reading the...
Well it depends on how much you sweat.
The sensors need to be wet to read correctly.
You can buy something called Heart Rate Gel cost about $5 to $10
Some people just lick the sensors on the watch strap and it works until they can start sweat enough..
Hope this helps.
Nov 03, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
I have a Polar F11 Heart Rate Monitor. The watch won't pick up the heart rate from the sender (00 is displayed), but my heart rate shows on a Polar enabled Gym machine, e.g. xtrainer. I've changed the...
There is a step by step guide in my tips and tricks of things to try with your strap. If none of these work and you are getting a signal from another source then you need to get either a new strap, a new sender or both. If you send the T-31 wearlink into polar they can run a diagnostic and see which is bad and sell you just the piece you need or a whole new chest piece.
Dec 15, 2010 | Polar F11 Heart Rate Monitor
I changed the battery in the f6 . I had erratic readings. Now watch seems fine but it wont read heart rate,,,,I get no heart beat at all .
Check out my tips and tricks section for a guide on troubleshooting heart rate readings.
One other possibility if you changed the battery yourself (never recommended) is that some damage or moisture has gotten into your watch and made it impossible for the watch to read heart rate. This is a more common reason than you think and why all manufactures of Heart Rate monitors and other types of watches have you send them in to their authorized service centers.
Dec 08, 2010 | Polar F6 Wrist Watch
Garmin 405 heart rate over 240
The device is displaying an incorrect heartbeat, otherwise, you would be dead. Try putting it on the other wrist and make sure it is positioned per the instructions. If the readings persist, contact Garmin Support for a replacement.
Apr 24, 2017 | Garmin Forerunner 405 010-00658-20
Heart rate monitor not working
Remove the batteries and clean the battery contacts inside the device with a common pencil. Then insert new batteries that you know are fresh. That should fix it. If it still won't work for you go to Garmin.com and send it in for repair. Joe
Mar 19, 2010 | Heart Interface Garmin 305 Gps Heart Rate...
My heart rate monitor keeps stopping picking up my heart rate (reading of 00 or --), i have changed the battery in the chest strap, not difference, any ideas?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all POLAR watch manuals. Rate me, please.
Mar 03, 2010 | Polar F11 Heart Rate Monitor
Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
Jan 03, 2009 | Timex Digital 30 Lap Heart Rate Monitor...
Seeing heart rate displayed on my polar compatible treadmill
i didnt knwo my treadmill was compatible i just hooked up like i wanted to read from my watch and then both started to read...although the treadmill had a bit of a different reading
Jan 02, 2009 | Polar S410 Heart Rate Monitor
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
New Balance 1400 Treadmill Logo
27 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
